Old 10-11-2007, 01:10 PM   #1
mister.freeze
mister.freeze's Avatar
Gear ratios
I was looking at an axle setup for sale somebody posted and they were 3.08 gears. Isn't that high? I'm guessing 3.73 is standard for a 4x4, and I did the math and 3.35 would gain me 9% gass mileage. I've got a stroker in the Fox, and figure I can go with higher gears, but how high is too high?
'72 K5, known as 'the Fox.'
mister.freeze is offline   Reply With Quote
Old 10-11-2007, 01:38 PM   #2
1971K54X4
Member
Re: Gear ratios
Mine came with 3.07's
Korey
1955 Bel Air 2 door hardtop
1971 Blazer 4x4
1973 Z-28 Prostreet
1971K54X4 is offline   Reply With Quote
Old 10-11-2007, 02:12 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Gear ratios
My GM restoration pack shows for the 2wd K5 that 3.73 was standard for the 250 six regardless of transmission and standard with the 307 V8 with a three speed.
3.07's were standard for the 307 V8 and 4 speed manual or auto, along with any 350 V8 combo.
4.11's were optional for all and if it had the 3.73's then 3.07 was an option and if it had 3.07's then 3.73's were also optional.
For the 4wd K5 3.73's were standard with all engines except for the 350 V8 which it shows only got 3.07's.
For whatever reason it doesn't show any optional gear ratios for the 4wd K5's.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-11-2007, 02:29 PM   #4
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Gear ratios
My '70 has optional 3.73 gears.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 10-11-2007, 02:51 PM   #5
earl87gta
earl87gta's Avatar
Re: Gear ratios
my 71 blazer had 3:07 my 72 had 3:73 and my k20 burb had 4:57 rear 4:56 front.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 10-11-2007, 04:41 PM   #6
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Gear ratios
I've got the 3.07's in mine. My last K5 had 4.10's, but they were not stock. My first truck had 3.73's and I believe it was listed as an option on the glove box.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 10-11-2007, 04:45 PM   #7
earl87gta
earl87gta's Avatar
Re: Gear ratios
here is my favorate gear calculator http://www.grimmjeeper.com/gears.html
Earl
Old 10-11-2007, 07:38 PM   #8
BLUE THUNDER
BLUE THUNDER's Avatar
Re: Gear ratios
hey dude thanks for the parts, mario.
BLUE THUNDER is offline   Reply With Quote
Old 10-11-2007, 10:42 PM   #9
mister.freeze
Re: Gear ratios
I'd go from 9.16mpg w/3.73's to 10.74mpg w/3.09's.
You're welcome, Mario.
Old 10-12-2007, 02:07 AM   #10
the_goat
Re: Gear ratios
so with 33's and 3.73 gears would I even use the 4th gear if I put in a 700r4? at 65 I would still be under 2000 rpms.
the_goat is offline   Reply With Quote
Old 10-12-2007, 07:43 AM   #11
earl87gta
earl87gta's Avatar
Re: Gear ratios
a stock 700r4 I think torqe converter locks up at like 1800 RPM so you would just be getting in to it. I know the truck and the fire bird and the vet all lock at diffrent RPMs the vet having the highest I think it is 2100 but its been a while since Ive read up on that so I may be off some.
Earl
Old 10-12-2007, 10:33 AM   #12
Elwayno
Re: Gear ratios
You won't neccesarily get better gas mileage. Maybe on the highway with a stick but could be worse in town. Due to more slippage if you got an automatic it could be the same or really close. Just don't change it so much you have too much gear to pull the hills on the freeway. Mine is close now.
Elwayno is offline   Reply With Quote
Old 10-12-2007, 04:59 PM   #13
earl87gta
earl87gta's Avatar
Re: Gear ratios
true but if he has a T350 now it would make a difrenc plus the 700r4 has a lower 1st gear so he could use a higher axle gear if he wanted to and wouldnt loose as much low end power as a t350 would.
Earl
Old 10-12-2007, 05:04 PM   #14
Long Roof
Old School, New Style
Long Roof's Avatar
Re: Gear ratios
My Jimmy was optioned with 3.73's
The Good:
- 72 GMC Jimmy 4x4 - 307 cid / 350 th
- 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th
- 96 Chevy Impala SS - mainly stock
- 98 Chevy Tahoe LT 4x4 - all stock
The Bad:
- 86 Chevy Suburban 1/2T 4x4 - winter beater
The Ugly:
- 72 Chevy Suburban 1/2T 2wd - parts truck
Long Roof is offline   Reply With Quote
Old 10-12-2007, 05:18 PM   #15
Elwayno
Re: Gear ratios
Earl if you change trannies and such things can be different. I was just pointing out that there is no free lunch so to speak. Not trying to be a naysayer. Gas mileage on the freeway is mostly a funtion of drag and driveline friction. In town is more to do with weight/inertia/gearing/lead foot. If going 60mph takes 50Hp with 3.73's it will take 50Hp with 3.07's. There may be very marginal gains because of the friction of the gears themselves but ignore that for a second. So if you change gears your engine slows down say 18%. Most likely your motor doesn't make as much power there so you have to push down on the gas harder. So you end up using the same gas. Now maybe you have a big block that makes a gob of torque everywhere, then maybe you don't have that problem, you lower rpm and get a gain in less loss from the part aoround the rings and piston that doesn't burn. Maybe you have a small block and you end up pushing the rpm down far enough you are off the torque peak completely and the engine is less efficient. Engines are most efficient at peak torque. As in the amount of gas used per Hp made goes down slightly so you don't want to get too far away from that. If it were jsut as ez as puttin higher gears I would get some 1.0:1's made and quadruple my gas mileage. We all know that won't work well.
Old 10-12-2007, 05:26 PM   #16
earl87gta
earl87gta's Avatar
Re: Gear ratios
I wasnt disagreeing with you. He didnt say what trans he had now but most guys that go to a 700r4 are swaping from a t350 wich is geared almost the same as a 700r4 so it wouldnt make that big of difrenc. Now if he had a sm465 or something I would think diffrent.
Earl
Old 10-14-2007, 04:17 PM   #17
Jimmy72custom
Jimmy72custom's Avatar
Re: Gear ratios
I have a 72 Jimmy 350 / 465 / 307 / 33x12.50x15 / I run about 2200 rpm @ 65 MPH. I do notice the freeway hills. I have been thinking about a gear venders OD, to raise my 3rd gear to for the freeway hills. I have not checked my MPG, something I should do.
Jimmy72custom is offline   Reply With Quote
