Alright Alright Alright
how do you remove bearing races from a rotor
im in the process of replacing the wheel bearings in my truck, but i dont know how to remove the old races from the rotor. i have tried using a flathead screwdriver and a big hammer, but they didnt budge. what do yall suggest?
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
Re: how do you remove bearing races from a rotor
Get a large steel punch and a good hammer. You are losing force from the soft screwdriver handle.
![]() Join Date: May 2005
![]() You've probably already seen the two notches inside the rotor. Place the punch there and commence to bangin'. Pete |
1997 GMC Sierra Ext 1965 Mustang |
good call. i give it a shot. i heard somewhere that i should use the old races to install the new ones. is that the most efficient way?
get cheap one of these to put them back in http://www.harborfreight.com/cpi/cta...emnumber=92387
Earl 68 2500 4x4 GMC Burb |
If you have access to a welder run a short bead in the center of the bearing from inside to out or center of rotor to exterior of rotor and it will come out easier. Stinks like he!! but works.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
