Old 10-11-2007, 05:08 PM   #1
AlienYouth
AlienYouth's Avatar
carb issue?
so, my gas gauge is broken, but i didnt know that... i ran out of gas, but didnt figure that out for a while... so while i was troubleshooting, i put the filter on backwards and flushed all the crap it caught over the years into the carb... something was keeping the needle valve open so it was shooting gas out, so i rebuilt it, no more gas shooting out, but know to the main point... when i give it a good pedal of gas is sputters and backfires, and i have to give it less gas as the rpm's go up to keep it from doing so... any ideas? thanks
Picturesss
71 C10 383/TH400
13.65 @ 99... 2.06 60' spinnin :/
AlienYouth is offline   Reply With Quote
Old 10-11-2007, 05:10 PM   #2
AlienYouth
AlienYouth's Avatar
Re: carb issue?
wow, im stupid, could some1 put this in engine?
Picturesss
71 C10 383/TH400
Old 10-11-2007, 05:34 PM   #3
2bits
2bits's Avatar
Re: carb issue?
Rebuild the carb again Sorry
_______________
Thomas
'78 Silverado
'74 Monte Carlo
'47 Teardrop Trailer
East Texas Classics Local Club
2bits is offline   Reply With Quote
Old 10-11-2007, 05:43 PM   #4
Blue71LWB
Blue71LWB's Avatar
Re: carb issue?
Make sure all your vac lines are hooked up. And make sure all the linkage is connected on the side of the carb.
Did you set your metering rod as stated in the rebuild kit? Also if you removed the valve below the metering rod their is a good chance it is not set correctly (I think most carb kits warn about removing this valve).
Thanks,
Zac
Working on my first 1,000 post.
I'm sure I'll get there before this project is over .
Blue71LWB is offline   Reply With Quote
