Old 10-11-2007, 05:11 PM   #1
JHART
1972 Shorty Owner
JHART's Avatar
Location: Stationed in Cali , born and raised in PHX Arizona.
Tranny leaking - Cant find from where - HELP!
Ok .... i have BRAND NEW TH350 with a shift kit installed in my truck and the thing is pissing me off.
Anytime i let the truck sit for a lengthy period like a week or more it leaks tranny fluid ... and allot of it. Cant figure out where its coming from but i cant keep letting this happen.
Any ideas? I really dont want to but if i have to i will rip the thing back out of the truck and take it back to the shop. But i dont have time for that right now i am in the military getting ready to deploy.
Any advice is greatly appreciated.
-Hart
1972 Chevy Shorty C-10- Project In Work
http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project
JHART is offline   Reply With Quote
Old 10-11-2007, 05:23 PM   #2
Luvlegs
Luvlegs's Avatar
Re: Tranny leaking - Cant find from where - HELP!
I'd start with some cardboard underneath to help spot where the leak is dropping from then follow back to where it's leaking - try to toss a little sand on the cardboard (thin layer) - that way, if it puddles and runs off, you can get a better idea of where it's actually hitting.... I say all this assuming you just cant find any fluid on the truck... One other thought, check your coolant - could it possibly be leaking through in the radiator (if your's is run through the bottom part of it)... good luck.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 10-11-2007, 05:25 PM   #3
skokie
skokie's Avatar
My 400 turbo does that after I let it sit for more than a week. Did that since it was freshly rebuilt.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 10-11-2007, 05:28 PM   #4
JHART
1972 Shorty Owner
JHART's Avatar
Thats what i am saying is this normal?
Old 10-11-2007, 05:37 PM   #5
sick69
sick69's Avatar
Shouldn't be "normal" I have my engine and tranny mocked up and my 400 is leaking from the dipstick tube. I've had this tranny in two different vehicles and after the first rebuild it didn't do it. after the second it has, I think the o ring is too small.
Might want to check the pan gasket aswell those things are easy to squash, which causes them to leak.
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 10-11-2007, 05:40 PM   #6
JHART
1972 Shorty Owner
JHART's Avatar
I checked the pan ... gasket still looks brand new and no residual fluid anywhere.
Old 10-11-2007, 05:53 PM   #7
brianthelion02
Overdrive club
brianthelion02's Avatar
As youre tranny sits idle,the torque converter will slowly drain back into the transmission and fill it up beyond where the fluid while the motor is running,soo you need to check the oring seal at the detent cable and also the selector lever shaft seal may be bad,either one doesnt require removal of the tranny!!When the trannyn is in use everyday it usually wont leak at these points cause the fluid stays in the torque converter,this is a very common problem and easily fixed!!!!!!!Good luck!!!!!!
1971 c-10
1951 3100 chevy
1970 chevy c-30 Sold!
brianthelion02 is offline   Reply With Quote
Old 10-11-2007, 06:26 PM   #8
BHRS
BHRS's Avatar
Look at the dipstick, vacuum modulator, kickdown cable, and possible the input shaft seal in the front of the pump. Remove the dust cover under the flywheel/flexplate and see if it is oily below where the converter slides into the trans. Front pump seal means removing the trans to fix it...
Brian
1972 Cheyenne C10
Unrestored Original-3 Owner-RUST FREE Texas Truck
Big Block-TH400-PS-PB-AC-AM/FM Radio
BHRS is offline   Reply With Quote
Old 10-11-2007, 09:44 PM   #9
kxnomore
kxnomore's Avatar
Mine did the exact same thing. It drove me nuts, but turned out to be very simple. The dipstick tube was re-installed into my brand new tranny with the original old o-ring. Then when the fluid in the torque converter would drain out after a couple of days it would leak all around the edge of the pan and drip from about 15 different places.
All I did was pull the dipstick tube, put on two (it may only have needed one, but I figured two would be better) new o-rings, put it back together, and it hasn't leaked a drop since.
kxnomore is offline   Reply With Quote
Old 10-11-2007, 10:39 PM   #10
longhorn70gmc
longhorn70gmc's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=257913
Hello,
No that is not normal and the thread above talks about this same problem and what we did to fix it. The issue is quit common amonst our trucks. I stopped the big leak, so now it wants to come out the o-ring seal in the tail of the transmission. Good luck on your fix. Look forwards to hearing how you fixed it with out removing the tranny.
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Old 10-11-2007, 10:42 PM   #11
crzngmychvy
"1972 C5"
crzngmychvy's Avatar
Same problem, and I've tried a few times to find the problem, but haven't yet.
- 72 2wd Blazer ...sold...
2wd Blazer Page
crzngmychvy is offline   Reply With Quote
