10-11-2007, 07:00 PM | #1 |
brake and axle questions....New Member
i have a couple of question, which some of you may think thet're kinf od dumb, but this is going to be a new experience for me. I have a 1964 3/4 ton 2wd fleetside long bed. i want to change the wheel bolt pattern form 8 to 5 and convert the fronts to disk brakes.
Now my questions are: I've been looking at different websites for the parts and so far every single one 'ive seen only offers kits for the 1/2ton. will these kits also fit the 3/4 tons or not? if no, why not? as far as the rear goes can i just switch out the axles or do i have to change the whole drivetrain? thanks |
10-11-2007, 10:55 PM | #2 |
Re: brake and axle questions....New Member
You have to change out the whole rearend. You can use a 71-72 rear end and they are already 5 bolt. If you have leaf and not coil springs you might be able to use a later model rearend but i'm not totaly sure of this.. If you have coil springs then you are better off looking for a 71-72 rear end... They bolt right in..
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
10-11-2007, 11:35 PM | #3 |
do only the 71 72 rear ends bolt right up or are there any other rear ends that will fit it.
10-11-2007, 11:57 PM | #4 | |
Shawn |
10-12-2007, 09:36 AM | #5 |
If he did that to a 3/4 ton then you can do it too.. The 71-72 1/2 tons are the only ones that are 5 lug with coil springs. In 73 they switched to leaf springs.. Also if you switch to a 1/2 ton rear you can put higher gearing in for better freeway speeds.. I forgot to mention that you can probably pick up a whole rearend for less money then to just buy the axles... I got mine at pick and pull for $110...
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 10-12-2007 at 09:43 AM. |
10-12-2007, 11:03 AM | #6 |
Yeah, I was also thinking i could get the whole rear end at cheaper price. Now as far as the Front brake kits go, do the kits they sell on LMC truck fit the 3/4 tons? I'm asking this because it specifies that it will only fit the 1/2 tons.
10-12-2007, 12:50 PM | #7 |
You will have to change out the ball joints for half ton... I used the whole front suspension from a 75 1/2 ton.. Steering box, center link, idler arm, upper and lower control arms. If you do this you have to redrill for the idler arm..
10-15-2007, 10:20 PM | #8 |
Whats the difference between the 3/4 ton and the 1/2 ton ball joints? Is it alot of trouble fitting the disc brakes on a 3/4 ton?
