Junior Member
70's Van steering column question
Can someone tell me Exactly which 70's van columns work on the 67-72's? Every post that Ive read about this conversion refers to it as a "70's van column". I went to the junkyard and they have a 76 van with tilt column for 35 bucks, but i wasnt sure if it would work or not. Can someone help? Thanks.
Re: 70's Van steering column question
I am assuming you are looking at a GMC or Chevy van.
Basically, if the key isn't on the column it will work. If that column looks similar to yours it will work. A 76 GM van with tilt will be the correct tilt, unless it's been changed out to the keyed style but I can't see that happening.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Junior Member
Sweet thanks man!!!
One quick way of looking for one, is as you are walking down the junk yard isle, just look at the Chevy/GMC vans for round headlights. Then look inside. Saves a little on the going back and forth. 70c10 pointed this out to me. Also, I believe that all van tilts up until 1981 will work. After that, they went to the key in the column.
1997 GMC Sierra Ext 1965 Mustang |
sounds like you got a good deal. latly its like thesalvage yards know were using them in our truck and the prices have went way up on them.
Earl 68 2500 4x4 GMC Burb Last edited by earl87gta; 10-12-2007 at 08:00 AM. |
