Old 10-12-2007, 01:47 PM   #1
bowtier
Nobody rides free
bowtier's Avatar
Red face Silly Rad question
I ordered a new radiator from summit for my '86. Well, the one I'm replacing is the 3 core (1 5/8"), and the new one is 4 core (2 5/8"). So I'm just wondering if I need different rad support brackets (the rubber pads) and new hold down brackets? I don't think I do, I'm pretty sure the "frame" of the rad's are the same width and the extra inch is just the core itself??
'71 C10 LWB 400SB/350TH
'86 K2O LWB 350SB/400TH-6" tuff country lift, Shackle flip - plow truck
'06 HHR - wifes wheels
'01 Blazer - daily driver
"It's better to burn out than it is to rust."
-Neil Young
bowtier is offline   Reply With Quote
Old 10-12-2007, 02:38 PM   #2
Pyrotechnic
Pyrotechnic's Avatar
Re: Silly Rad question
The tanks and mounting area are bigger on the 4 core radiator and they do require larger rubber pads, at least stock replacement radiators anyway.
Pyrotechnic is offline   Reply With Quote
Old 10-12-2007, 03:47 PM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
My 2 and 3 row had the same size tanks. The four row required new hardware, or I would have gone from the 2 row to the 4 row. Again, this is on a stock replacement radiator.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 10-12-2007, 03:56 PM   #4
bowtier
Nobody rides free
bowtier's Avatar
Thanks guys.
-Neil Young
Old 10-12-2007, 05:54 PM   #5
Prerunner1982
Prerunner1982's Avatar
here is a picture of the top hold down. You will need 4 new rubbers.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 10-15-2007, 03:41 PM   #6
bowtier
Nobody rides free
bowtier's Avatar
Ok, adding to my confusion somewhat. My hold down doesn't go all the way across. I have 2 seperate brackets at each end of the rad. I found the hold down you show on classic parts site. But I think it's just a cover, and not the actual hold down. The GM garage here in town said they could order the wider rubbers in. But I still don't know if my hold down brackets will work. I should have the rad. tonight so I can get it in and see how everything fits up. From looking at that picture, I'm worried I won't have room for my fan shroud. Did you leave yours out by choice, or did it not fit??
Thanks again.
-Neil Young
Old 10-15-2007, 09:28 PM   #7
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
If I remember correctly the 2/3 Row use the same brackets, the 4 uses a different set (speaking of factory only)
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 10-15-2007, 09:44 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Are you running a fan shroud? If so it's going to need trimmed....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-16-2007, 07:39 AM   #9
bowtier
Nobody rides free
bowtier's Avatar
That's what I was thinking. I fit it all up last night and my inlet/outlet are not the right size, the fan shroud didn't fit, and the brackets and rubbers are too small. I can't locate the right brackets or rubbers anywhere, even checked the chevy garage. How can this stuff not be available?? I might have found the rubbers in LMC, they only note *for heavy duty radiator, but they don't actually say how wide they are. I need them to be about 3 1/4" instead of the stock 2 1/8" ones. I'm going to give them a call today.
Anyone have any ideas on the wider brackets??
Thanks again, I honestly didn't think this would be so hard for me.
-Neil Young
Old 10-16-2007, 08:47 AM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
You need brackets, etc for a big block equiped vehicle. That's how I got the ones I put in my 82 Blazer. I "think" I bought them from GM but that has been a few years ago.
The shroud worked, I just had to trim it a little to clear the clutch on the a/c compressor.
Articles-
"Refining Sierra"
Old 10-16-2007, 08:51 AM   #11
bowtier
Nobody rides free
bowtier's Avatar
Makes sense, thanks.
-Neil Young
