Old 10-12-2007, 11:45 PM   #1
salazar44
65 - Chevy C10
salazar44's Avatar
Brake Lights / Blinkers / Tail Lamps
Ok guys... I just installed some cheap $6 tail lights/signals/blinkers as a temporary fix until I can get my bed on. The problem is that I can get my blinkers to work fine, but when I turn the headlight switch on the tail lamps dont go on. Also, when I press the brake pedal the tail lights dont light up. There are some instances when I have the blinker on and I press the brake pedal the blinker will actually switch to the wrong side. Not sure how to repeat that error??
VIC
One Repair Leads to Another!
http://vix65chevyc10.blogspot.com
salazar44 is offline   Reply With Quote
Old 10-12-2007, 11:45 PM   #2
salazar44
65 - Chevy C10
salazar44's Avatar
Re: Brake Lights / Blinkers / Tail Lamps
How can I tell if my brake switch is bad?
VIC
Old 10-13-2007, 12:10 AM   #3
poorboy
poorboy's Avatar
You can unplug it and run a jumper wire on the wire. If the lights light up then the switch is bad.
63 short fleet Patina build
http://67-72chevytrucks.com/vboard/s...d.php?t=287751 Man I want another one.
poorboy is offline   Reply With Quote
