Old 10-13-2007, 12:19 PM   #1
wlarue72
73-87 control arms on 72??
I recently purchased some later model control arms to put on my 72. I am doing this to get a better ride. My question is, is my truck going to sit at the same height as it does now. Looking at the later model arms, it looks as if the spring cups are more shallow, which it seems to me would raise the height. Advice please?
72 Cheyenne Super 402 daily driver. A lifetime project!
wlarue72 is offline   Reply With Quote
Old 10-13-2007, 01:03 PM   #2
SCOTI
SCOTI's Avatar
Re: 73-87 control arms on 72??
The a-arms might change the ride height enough to notice w/a tape measure. But..... visually, you prob wouldn't be able to detect a difference.
When my buddy did this swap recently, we did notice the later springs were taller than the earlier springs. Since I was helping him w/the disc brake & suspension swap (along w/a mild altitude adjustment), we went w/the shorter, early-model springs & it worked well.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-13-2007, 01:54 PM   #3
wlarue72
Thanks Scott, I was thinking about using the later springs as they are for a small block and the ones I have on there now are big block springs. Think they might make up for the difference? I am eventually gonna go with 2.5" drop spindles..... David
Old 10-13-2007, 02:02 PM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
I just did this exact swap om my trucks. If there is a change in ride height, it is negligible...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-13-2007, 09:54 PM   #5
impala_631
:( BYEBYE :(
impala_631's Avatar
what does the swap do for the truck? a better ride?
impala_631 is offline   Reply With Quote
Old 10-14-2007, 01:13 AM   #6
SCOTI
SCOTI's Avatar
Rubber bushings vs. rubber-lined steel bushings. Less harsh ride quality & better vibration/harmonics dampening.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-14-2007, 08:26 AM   #7
gringoloco
A guy with a truck
gringoloco's Avatar
Cheaper more readily available parts and shorter cups if you're bagged...
-Chris
Old 10-14-2007, 03:24 PM   #8
wlarue72
Old 10-14-2007, 05:21 PM   #9
hotrodhomi
hotrodhomi's Avatar
why shorter cups if bagged. Are the "72 arms recesses more? Will the spindles interchange?
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 10-14-2007, 11:06 PM   #10
gringoloco
A guy with a truck
gringoloco's Avatar
The '73-up arms are shallower, allowing for about an inch shorter cup than with the '72-down arms. Spindles are interchangeable with a balljoint/tie rod swap. Easy upgrade with the 71-72 as you only need upper balljoints and outer tie-rods; the earlier ones need more parts swapped out...
-Chris
