Old 10-13-2007, 07:45 PM   #1
salazar44
65 - Chevy C10
salazar44's Avatar
oil pressure / water temp
Can anyone show me where they are running their aftermarket gauges (water temp, oil pressure) to their block?
Currently, Im using the stock water temp under the driverside exhaust manifold. and the oil pressure (electronic) in the stock location. Im just curious if I can move my water temp elsewhere, away from high temp manifold.
VIC
One Repair Leads to Another!
http://vix65chevyc10.blogspot.com
salazar44 is offline   Reply With Quote
Old 10-13-2007, 08:24 PM   #2
Dadsredwagon
Dadsredwagon's Avatar
Re: oil pressure / water temp
on my 230 motor mine is the same location you say yours is,not running electronic though
Dadsredwagon is offline   Reply With Quote
Old 10-13-2007, 09:11 PM   #3
NF65Fleetside
NF65Fleetside's Avatar
Im running my water temp from the intake manifold location and Ive yet to install my electric oil pressure...want to help me with that next weekend?! hehehehe
NF65Fleetside is offline   Reply With Quote
Old 10-13-2007, 10:43 PM   #4
salazar44
65 - Chevy C10
salazar44's Avatar
lets do it!
VIC
Old 10-15-2007, 06:09 PM   #5
60ratrod
yes, i do
60ratrod's Avatar
sal if you have a 350 then the only other place that i can think of would be from the intake manifold in the front part of the intake. i actually have my electric fan sensor in that location. if you can't get that to work then i would suggest making a sleeve for the wire out of header wrap or something like that
60ratrod is offline   Reply With Quote
Old 10-15-2007, 07:00 PM   #6
jchav62
1962 C-10
jchav62's Avatar
That's where mine is hooked up. Works fine, but at first the gauge jumped around a bit. Like there were air pockets in the circulation or something. I heard the best place to hook it up is on the side of the head where you have it. My heads didn't have a place for it there, that's why I went to the intake.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
