05-02-2002, 01:00 PM | #1 |
Dual Fuel Tanks
I am thinking about putting a second fuel tank in the burb. I was wonder where I can get a switch to use to switch between tanks. Also is there a way for the 2 sending units to read on the stock fuel gauge when the tank is in use? Thanks
------------------ Check out other members trucks 1968 50th Anniversary C-10 Suburban (Tows all these cars all over the place) 1968 50th Anniversary C-10 Pickup 1968 50th Anniversary C-20 Pickup CST, FOR SALE 1969 SS Camaro Conv't 1960 Lakewood Travel Trailer 1963 Ford Falcon Wagon, On Ebay for $1250 2000 Chevy Malibu (Suppose to be daily driver, but the Burb is) Phoenix, AZ. Click Here for Parts and Venicles I have Available THINGS I AM LOOKING FOR: 67-68 SUBURBAN TRIM. $$$$ Reward for finding the 3rd door trim piece and the small piece that goes on the 1/4 panel right behind the 3rd door.
Just sitting here contemplating contemplation. |
05-02-2002, 01:03 PM | #2 |
I know you can get your gauge to read for either tank you are using, but I'm not sure how they do it. I'd call an RV dealer to get started. I know the guy I got my receiver hitch from does that kind of stuff too.
------------------ 56 Studebaker 2 dr Wagon 66 Chevelle 2 dr 4 speed 71 C30 Longhorn 86 Monte Carlo SS 96 Tahoe
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
05-02-2002, 03:51 PM | #3 |
I have Duals and the factory(?) setup has a switch above the left side A/C outlet on the dash. If you don't have A/C just pretend for the moment. The switch is used to change over the sending unit wires to the gas gauge. The tanks are actually switched using a manual valve on the floor by the drivers side seat adjuster. This selects the tank you want to use.
This is old technology but it works. A better way to do this is to use a solenoid valve to change tanks using the same switch as the sending unit. The problem with the factory set-up is that the sending unit could be reading one tank and the gas valve on the floor switched to a different tank. No big deal...just details. J.C. Whitney has a electric operated solenoid valve. It's about the only place I've seen them listed. Don't know where you could find a manual one. I think Jeff (CPNE)posted one for sale a while back but I don't know if he still has it. ------------------ Orlando,FL 72 Chevy 4x4 3/4T CustomCamper w/SB 406
............................................................ 68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements. |
05-02-2002, 04:02 PM | #4 |
If you go with an electric solenoid type of
fuel selector that uses a switch to select the tank...just use a relay in that circuit to also select which sending unit is used. That way, what ever tank is being drawn on will *always* match the fuel level sender.. No thinking required. ------------------ 71 Chevy C-10 SWB Fleetside WAS:307w/3-on-the-tree NOW:350TBI/700R4/3.73 See it at www.prismnet.com/~grzanich
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
05-02-2002, 04:28 PM | #5 |
Bubba..that's what I plan on doing someday. The problem with the factory set-up is that the gas lines have to be routed under the cab to get to the drivers side and then run back again to get to the fuel pump. Not a very clean way to do it. The solenoid and wiring is a cleaner way to do it. A double pole switch could also be used instead of the relay..again less clutter. Either way works though. I kinda was trying to say earlier that it was "old" technology and today ther are better alternatives.
