10-13-2007, 10:02 PM | #1 |
Rebuilt the engine in Green Machine - now 20 + MPG & more power !!!
A little background - we "rebuilt" an 89 Camaro 305 roller motor during the build of the 1970 and installed it last summer. The "rebuild" was just rings and bearings and gaskets, tchain, oil pump etc. Did not touch the heads as there were no leakers. Had to put in a good set of used roller lifters because they were all stuck from the PO's bad oil change habits and reused the stock roller peanut cam.
Results were pretty good - nice power and 18.5 mpg with the overdrive A833 4 speed manual, but we developed a miss the first part of August this year. Compression test showed 50 psi on hole 5, suspected valves, but the motor had always sounded plenty loose and getting worse with a suspected loud piston slap on at least one hole. We were not going to mess around this time so out it came. Yes I know you should remove the ridge when attempting a re-ring job but we did not have access to one then. Number 5 piston had a stuck top ring and so did one other hole, with evidence of the fire sliding down the side and melting some aluminum away !! All pistons were loose enough in the bore that its is a wonder they did not swap holes !!! Thats the bad. Now the good - Had block decked about .010 to square it up an bored .030 over. Got some Silvolite rebuilder hypereutectic 4 valve relief pistons (destroked .020) to replace the slight dished stock pistons. Had engine balanced , new slugs were a bit heavier than the the old ones. Had heads shaved enough to clean, all guides were good yet but stems were wore on exhaust, so new exhaust valves went in to tighten that up and a set of "Z28" springs with the rotators retained to make sure the bigger cam won't bounce the rollers when we get rowdy. Opened up the top ring gap. +004 to .020 per conversation with Silvolite tech to avoid any possibilty of ring butting. Pistons ended up about .035 in the hole, with a .040 gasket about .075 deck (yeah, I do know about quench but.. compression ratio is about 9.3 with this set up and we want to run 89 octane. Got new takeout HT 383/Ramjet 350 roller cam (has fuel pump lobe) from Ebay for about 65 bucks, reused the used roller lifters again with stock rocker arms and pushrods and resused the performer intake and carb and HEI that was on there. Installed cam 4 deg retarded to reduce dynamic compression and vacumn a bit, keep the push on the piston a little longer, and extend the top end. Engine fired up first turn over - ran about hour put on about 50 miles and dumped oil and filter. Results- Lot more power than before - 190 cranking PSI (ouch - more than we we hoping) Had to redo the dizzy, only 4 initial plus 20 in the dizzy all in by 3200 with stiffer springs an 10 in the can to eliminate pinging on 89 Gasohol. Now I know we violated a few engine building rules here, large quench distance, retarding the cam and using "doggy" swirl port TBI heads, but the proof is in the pudding. It will surely spank any stock 350 an get better mpg to boot. Went to a car show and cruise 100 miles away last Sunday, engine only had about 300 miles on it when we left so it still may be a little tight. Drove down 100 miles pushing a slight headwind and then drove another 65 miles thru some parks and scenic areas, lots of idling, stop and starts, hills 2nd & 3rd gear, never got into overdrive. Got 17.5 on that leg of the trip. On the way back with a slight tailwind, lots of stops and starts, (not a straight shot) we got the 100 miles done on 4.9 gallons !!! And we still don't have headers on yet. We be smilin now
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 10-13-2007 at 10:11 PM. |
10-13-2007, 10:42 PM | #2 |
The Older Generation
Re: Rebuilt the engine in Green Machine - now 20 + MPG & more power !!!
Even though I don't know half of what you are talking about, it still sounds good... ..Glad you are getting the performance, and the bonus mileage too... LockDoc
10-13-2007, 11:03 PM | #3 |
good deal, what gears have you got? how do you like that tranny? gathered one of them for my next project, but never have driven a truck with one to know what i thought of one
common sense isn't so common anymore |
10-13-2007, 11:20 PM | #4 |
Love the OD tranny, gears are spaced just like a standard 3 speed, but there is one more shift to over drive. We have 3.73 posi with 265/70 R17 tires all around. I think they are about 31.5 tall. 60 mph is 1700 rpm, and yes the speedometer is calibrated perfect, so I know our mileage is accurate.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
10-13-2007, 11:38 PM | #5 |
I had a 82 C10 with that trans........loved it. thinking of one for my 69
10-14-2007, 12:42 AM | #6 |
Out of the carpool lane.
'89 305 huh? Very interesting. Thanks for the detailed write up!
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
10-14-2007, 01:58 AM | #7 |
my s.b. 383 with a th350 and 3.08,s gets 17.5 if i drive it right.
I BELIEVE IN JOHN 3:16 |
10-14-2007, 09:08 AM | #8 |
Is the A833 the manual floor shift 3spd+o/d?
10-14-2007, 09:21 AM | #9 |
Old member
I have the 86 (stock) IROC -305 HO TPI motor in the 71 with a 700-R4 with the corvette upgrades in the transmission and driving it on the interstate I get 20 MPG. These little motors are a good choice for our trucks that aren't built for speed. I can run up to about 95 with the 4:10 gears before it starts loosing power, but it pulls good all the way.
10-14-2007, 09:32 AM | #10 |
Official Site Guitar Shredder
wow shure ... great write up.the 67 gets about 14 mpg with stock everything my 72 lol.....8-10mpg i got to change those 4.56s lol.....naw it pulls so good.....good job....
10-14-2007, 10:31 AM | #11 |
Sounds like a great build!
10-15-2007, 12:16 AM | #12 |
Sounds awesome... way to go guys... scary part is I did understand what you were saying.... For everyone else, I ve seen and drivien the "machine" pre engine rebuild and it drove like a dream then... wow... their engine choice is one of the best around (with the roller 305) for both performance and mileage. I have been on the look out for a roller 305 since I drove thier truck last march. Anyway, Im tired and Im rambling, but congrats on the build!!!
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
10-15-2007, 07:02 AM | #13 |
only scary part to me is why did you reuse the lifters? I've always been thought in school to never reuse lifters even roller lifters
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
10-15-2007, 07:15 AM | #14 |
I wasn`t surprised to hear you had to go back and take care of the heads.Bottom ends outlast heads/top ends.The problem most have is doing the top end only to have blow-by on down the road from the rings.But,guides and cams are the first to go.
10-15-2007, 05:08 PM | #15 |
You can reuse rollers, but never, NEVER reuse flat tappets! Sounds good, I have two roller 350 blocks, I think in a mild form such as yours 18-20 mpg may not be out of reason. Roller is a big part of that equasion, less friction. My problem and most everyone else's here is that we put our foot in it and the MPG goes down the drain!!
10-15-2007, 05:23 PM | #16 |
oh okay i was just told never to reuse them
10-15-2007, 07:37 PM | #17 |
I am a Referee of life.
Green Machine, sounds like a near perfect build for a cruising engine.No radical stuff just good straightforward rebuild with some mild performance goodies and a well thought out plan to get to a defined goal.
Glad it worked so well.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-16-2007, 11:59 AM | #18 |
Next project: 1970 K10
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
10-17-2007, 10:09 AM | #19 |
I would assume Cylinder pressure.
If he has 190 lbs of oil pressure, the filter will fly, and probably a lot of gaskets, too.
No Truck for me yet, Still Looking. |
10-17-2007, 11:30 AM | #20 |
Nice job. I'd like to build a gas sipper one day too. Maybe a destroked roller 327.
10-17-2007, 06:01 PM | #21 |
Who's got steelies?
Wow, this is like an inspirational thread for me. Your getting better MPG than most of the new trucks, too!!!
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
