Old 10-14-2007, 10:06 AM   #1
Oldironracing
Oldironracing's Avatar
4 link
I have a 72 long bed. Looking to put 4 link and a ford 9 inch narrowed to fit wider tires under. Not going to cut the frame for the narrowed rear. Wont the truck to hook up under power lots of power. What is the best 4 link set up out there you guys have seen? I still won't the truck to be streetable.
THANKS Guys
OLDIRONRACING
Oldironracing is offline   Reply With Quote
Old 10-14-2007, 04:39 PM   #2
shifty
Questionable
shifty's Avatar
Re: 4 link
i wouldn't go with a 4-link, i'd go with a 4-bar. 4 link installation is more configurable, but 4-bar is perfect for what you seem to be looking for.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 10-14-2007, 06:25 PM   #3
Oldironracing
Re: 4 link
What is the differnce.
OLDIRONRACING
Old 10-14-2007, 08:49 PM   #4
CHRIS67GMC
CHRIS67GMC's Avatar
Re: 4 link
No limit engineering http://www.nolimit.net/prodinfo.asp?number=FTBR%2DBC I have used these many times. You do not want a paralel 4-bar they do not transfer power! I have the fat bar on my truck runs 11.60s with a 1.58 60 foot.
CHRIS67GMC is offline   Reply With Quote
Old 10-14-2007, 09:08 PM   #5
shifty
Questionable
shifty's Avatar
Re: 4 link
4-bar is way easier to install and adjust.
more reading info is here:
http://www.syty.net/forums/showthread.php?t=7466
if you need pictures, this is a 4-bar :
http://www.checkeredracing.com/files...ar/4Nova2L.jpg
here is a 4-link:
http://www.checkeredracing.com/files.../4LinkKitL.JPG
welding on the 4-bar is easier, welding on the 4-link is tougher, but you get more adjustability. something to note about the 4-bar kit, i believe most of them come with adjustable rods/bars - the end links can be spun in and out to adjust the rear-end.
find some more reading specific to our trucks at this thread on the forum:
http://67-72chevytrucks.com/vboard/s....php?p=2393512
i have an episode of Horsepower TV or some other hotrod show on my Tivo right now that does a superb job of showing the difference between both (and a third chassis) from roughly two weeks ago - and it repeated this last weekend. i'll try to find it, but not sure what i can do with it once i pull it off i tried to pull something else for a board member recently and it was a nightmare
Old 10-14-2007, 10:32 PM   #6
shifty
Questionable
shifty's Avatar
Re: 4 link
oh, and i recommend chatting with the guys at the suspension forum about this before you proceed: http://67-72chevytrucks.com/vboard/f...splay.php?f=25
Old 10-15-2007, 09:23 PM   #7
Oldironracing
Re: 4 link
I tried the suspension forum but got no input.
OLDIRONRACING
Old 10-16-2007, 11:56 PM   #8
Oldironracing
Re: 4 link
there helping now... THANKS
OLDIRONRACING
Old 10-17-2007, 04:35 PM   #9
onetonk5
Cereal Killer
onetonk5's Avatar
Re: 4 link
Bar=Link
If I dont do it....somebody else will.
onetonk5 is offline   Reply With Quote
