Old 10-14-2007, 03:40 PM   #1
Richard Dobson
When Oil Priming an Engine?
When Oil Priming an engine with a drill thru the distributor hole, I am using a drill turning in the clockwise direction. Shouldn't see oil coming up to the valve train thru the rockers? How long should I have to sping the drill before seeing oil in the cyl heads?
Richard Dobson
Richard Dobson is offline   Reply With Quote
Old 10-14-2007, 04:02 PM   #2
cdowns
cdowns's Avatar
Re: When Oil Priming an Engine?
it depends on the primer used// the best is the old distributor because its got the machined piece that allows the oil to flo up to the valve train// by just inserting a rod to drive the oilpump without that machined fitting oil wont get to rockers
Old 10-14-2007, 04:52 PM   #3
Richard Dobson
Thanks CDowns, I am using an old dist with the cam gear removed, turning it in the clockwise direction like the dist turns. How long do I have prime or run the drill before I can see oil coming to the top of the heads at the rockers? Thanks again.
Richard Dobson
Old 10-14-2007, 05:26 PM   #4
Billla
Billla's Avatar
Standard rotation is clockwise as viewed from above.
I'd expect to see pressure in less than 5 minutes, oil at the rockers in less than 15. It's pretty hard work for a 3/8-style drill, especially with an HV pump.
Billla is offline   Reply With Quote
Old 10-14-2007, 06:46 PM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
I imagine about a week or so, then go to the garage and use the drill--after that around 15 minutes for the rockers---need to work until all the rockers are oiling
piecesparts is offline   Reply With Quote
