10-14-2007, 05:28 PM | #1 |
Radio Installs
Hi All,
When I bought my '86 GMC, some asshat hacked up the dash bezel, and cut away the factory sheet metal of the dash around the original radio openings to install an aftermarket Sony CD player. It was so hacked up, it sat inboard about 2" into the dash, was crooked, missing the trim, and they used a bunch of black foam of some sort to make it look like it fit- but it didn't. To top it off, it didn't work. I tore it all out today to assess the damage. The radio works fine now, (no radio fuse was in the fusebox ) so I want to just basically un-do what was done and make it look more professional. (I've done many car stereo installs so I am familiar with the kits and adapters and such, but since this truck was never designed for this style radio: I was wondering if anyone out there has done a clean install using a newer-style aftermarket CD player, and what parts you used to pull this off and make it look presentable. My dash bezel is a hacked nightmare (see pics.) I can probably save it by laminating a new piece of plastic over the top of the now way-too-big opening, and re-cutting a new opening...but I am looking for other alternatives...such as finding an un-cut bezel, and modifying it a little more "neatly"...any pics of what you did? Last edited by mercman1951; 10-15-2007 at 12:56 PM. |
10-14-2007, 10:26 PM | #2 |
Robert Olson Transport
Re: Radio Installs
once the dash is cut up the only thing you can do to make it look professional is to get a new bezel. Ive seen a couple of people even cut the dash metal out of a donor truck and tack in the supports and put back an original radio and stick the CD player in the glove box
10-14-2007, 10:36 PM | #3 |
Re: Radio Installs
there is a white truck on there that has a killer looking install.
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq |
10-14-2007, 11:08 PM | #4 |
Gentleman Jim Driver
Re: Radio Installs
I just put a Pioneer CD player in my 86. It killed me to cut the dash, but I couldn't live with the broken tuner in my stock digital radio any longer. I've even tried several of the originals and after about 5 of them, I never had one where every function worked.
I bought my head unit from crutchfield (with a good discount code I found online). The install kit they included had the wiring adapter and a plate with a DIN hole already cut in it. The plate was big enough to cover even the big hole in your bezel. It's texture matches the dash bezel and it looks as good as a late model radio can... I'd try to get one of those plates. I've used one before from Sounddomain too. It was plastic and the screws went through it. The metal one from crutchfield was held on by the clamps in the DIN cage.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed Last edited by ElGracho; 10-14-2007 at 11:09 PM. |
10-15-2007, 04:50 AM | #5 |
>130dB Moderator
Re: Radio Installs
Mine:
Pioneer DEH-880PRS I used a steel mounting sleeve, which is standard with any aftermarket radio install, and I also used a sheet of ABS plastic to help get better results. This may be the way to go if you don't want to get a new bezel for some reason. My concern would have more to do with the wiring. Seeing how bad the rest of the job was hacked, I can't imagine much more care was taken with the wiring...
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
10-15-2007, 06:45 AM | #6 |
pkbinplano
Re: Radio Installs
I couldn't / wouldn't hack my dash, so I installed a Pioneer am/fm/cd under the front seat. Radio has a remote control. Out of sight for thieves also. Just had to buy an extension for the antenna wire
http://www.picturetrail.com/gallery/...7496&members=1 84 chevy silverado aka The Bananna Boat Last edited by pkbinplano; 10-15-2007 at 06:46 AM. |
10-15-2007, 07:44 AM | #7 |
Re: Radio Installs
I had a install shop in Calgary hack the bezel in my old truck, after that I said never again. I now have another truck and had the stereo mounted in the glovebox. Its done with MDF board, the guy at futureshop did a great job.
10-15-2007, 09:34 AM | #8 |
Re: Radio Installs
Since i´m not smoking and also have bucketseats i´m in the process of building a centerconsole that holds the headunit and subwoofer and functions as a storage and armrest and gives a nice customtouch!
It covers the Hole from the ashtray where i can route the cables through and only touches the floor in front and in back of the cab so i can light up the floor a bit!It will be covered with imitation leather,velours and painted accents! The gaugebezel wont´t be holding anything in that place anymore because it´s hard to reach and see! Last edited by moneyeater; 10-15-2007 at 09:37 AM. |
10-15-2007, 12:49 PM | #9 |
Dark Heart Motorsports
Re: Radio Installs
looks hot money... you gonna fg it at all?
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
10-15-2007, 12:55 PM | #10 | |
Re: Radio Installs
Yours is a very clean install. Exactly what I was looking for. I have some ABS I was going to use, but it's not textured. There's really nothing wrong with the rest of the bezel if I can get away with covering up the giant hole. Looks like I'll need to lengthen the antenna as well, that may have been why they didn't do such a hot job because there isn't enough slack to allow the radio to sit flush. Picked this up today: http://www.crutchfield.com/S-XcaPrm4...M16&c=3&tp=861 Thanks to all who posted! Last edited by mercman1951; 10-15-2007 at 09:07 PM. |
10-18-2007, 09:37 PM | #11 |
Re: Radio Installs
UPDATE: 10/18/07:
They delivered this the other day: http://www.crutchfield.com/S-XcaPrm4...M16&c=3&tp=861 So, here's what I wound up doing to solve my "hacked up dash bezel" problem...maybe other forumers can use this info: I got the trim plate from Crutchfield...fast shipping and good instructions as per the usual. Since my bezel was hacked up, I couldn't secure the DIN-style chassis (metal basket) in the normal way to hold it all in place, so I epoxied (is that a word?), the new metal trim bezel over the old plastic dash bezel that was hacked up. The metal DIN-style "cage" will slide into this, and I will slide the radio in place after I bend the cage tabs out against the backsides of the stock dash bezel/new plate. Does that make sense? There is also a metal strap that came with the kit to support the backside of the radio to a good place on the factory dash, so it will be supported in both the front and rear. I did have to buy an antenna extension wire, (a 12 inch one...5 bucks from the local car audio install place); because the stock windshield antenna lead in this truck is too short to allow the radio to seat where it needs to be in the revised opening. I will button this all up soon in the truck, but here are the pics that show the basic process...they are out of order I know, but you get the idea of the process... Last edited by mercman1951; 10-18-2007 at 09:38 PM. |
10-18-2007, 09:57 PM | #12 |
Re: Radio Installs
thats a good cover up mercman1951, nice job
10-19-2007, 10:26 PM | #13 |
Re: Radio Installs
Thanks, and a big thanks to ElGracho for tipping me off to the Crutchfield plate...I would have never thought they had something like this to go back that far in age. And also thanks to AceX, for the finished install pic that let me see what I needed to see.
Here's the final install as of tonight. Exactly how I'd hoped it would turn out, based on what I had to work with. As a bonus...the once non-working crapilly installed radio works fine...even the CD player part...now I need to upgrade those crappy 21 year old crackling factory paper speakers! Last edited by mercman1951; 10-19-2007 at 10:32 PM. |
