Old 10-14-2007, 09:00 PM   #1
ABN82MP
ABN82MP's Avatar
What Size Tire w/18" Wheels?
I'm currently running 16.5" aluminum slots with 9.6r16.5lt tires. My tires need replaced, but a local search, including Summit, only turned up 1 set of tires @ $277/ea.
So...I have approval from the wife to get new wheels and tires...something I've been wanting anyway.
I've decided on a set of 18" wheels but I'm not sure about the tire size. Can anyone suggest a tire that will be about the same height?
ABN82MP is offline   Reply With Quote
Old 10-15-2007, 10:54 AM   #2
ABN82MP
ABN82MP's Avatar
Re: What Size Tire w/18" Wheels?
Anyone?
Old 10-15-2007, 11:15 AM   #3
SactoJim
SactoJim's Avatar
Just put 18's on mine.
Tires are 275/55/18 & 255/50/18.
Tire's are around $150 each.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 10-15-2007, 12:57 PM   #4
hvychve
To The Levy
hvychve's Avatar
here is a set of 18" I installed
hvychve is offline   Reply With Quote
Old 10-15-2007, 12:59 PM   #5
hvychve
To The Levy
hvychve's Avatar
ooops I forgot picture,
Old 10-15-2007, 03:08 PM   #6
ABN82MP
ABN82MP's Avatar
Do either of you know the outer diameter of the tires?
Thanks,
-Jason
Old 10-15-2007, 03:21 PM   #7
SactoJim
SactoJim's Avatar
This calc will give you any tire diameter if you know the tire size.
http://http://www.miata.net/garage/tirecalcold.html
- supercharged 383
- 4 wheel discs
My Build Thread
Old 10-15-2007, 10:52 PM   #8
brake
A 9.5R16.5 is around 30.5" tall. A 265/60R18 is a fairly common size that's the same height and around 1" wider.
brake is offline   Reply With Quote
