Hunting is Life
having problem with short bed
I am having trouble getting the bed off my 70' shortbed. As usuale in minnesota everthing is rusted, i got the nuts loose, but now the bolts just spin. the bed is metal so i can't take a hammer and crowbar to it like i did with my 3/4 ton, anyway i am doing this alone, so does anybody have any ideas.
pat
1970 GMC K-1500 4x4 292 I-6 3 on the tree-prodject truck ![]() 1971GMC 2500 2wd 350-v8 sm465 4spd-parts truck ![]() 2005 Ford Ranger 4.0/5spd auto 4x4 extended cab--everyday driver bought new ![]() ![]() |
Step Brother
Re: having problem with short bed
air cut off tools...If you have access to them they work great..George
I usually grind the heads off the carraige bolt that is in thetop of the floor. Works everytime for me, and Im usually working alone.
67- 72 Parts collecter |
I have a radical idea!
Yep. I've got to where I just go ahead and grind them of regardless if they've never been off before. It keeps from ruining the square holes in the bed floor from the carriage bolts spinning.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
Roadtrip!
![]() Join Date: Feb 2003
I can't believe you found rust in minnesota! If you have a welder, set a nut on top of the bolt head and weld it on so you can put a socket on it and a wrench down below. Another thing you can try is to cut a slot in top and try to use a screwdriver. Not the best method, but may work. Living in MN, i usually just tighten the bolts until they snap off. Good luck, Eric
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
It was a pain by myself but I put a wrench on the bottom then hit the head with a drill bit (like tightening them up until the snapped) - they did one of two things - either they snapped right off or, as soon as the head was loosed from the bolt, the head started up the drill bit - it took about two hours alone but I didn't mess up a single square hole. Remember, it's a hobby so you can't curse while your doing it, it's fun right... hahahahah
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
ran out of money
another idea is go to sears and get a nut splitter and crack off the bottom nuts, grinding is good but messy and you have to be careful. a torch from the bottom would also work, just be careful
Modify everything, leave nothing alone!~ ![]() ![]() |
I just get under mine with the torch and heat them up and cut the bolt off...haven't put any holes in anything yet and I've done 4 trucks recently like that.
Hunting is Life
i plan on turning it into a 3/4 ton flatbed, so i don't care if i ruin the bed.
pat
The easiest way by far is to just tighten them until they break off! This is easiest with a 1/2" impact gun and a 6 point socket. Works great!
Hunting is Life
i don't have access to air ttols or know anybody with them evrything has to be done with muscle, i'm heading up this weekend to work on it more. after last time i just want to take X-pounds of C4 to the bed.
pat
Hunting is Life
this weekend i am going to try a saws all or C4
pat
#13 |
just arm yourself with a ratchet and a length of pipe maybe 2 feet long to add to the handle. You can break them off by tightening them WAY easier than using a sawzall. But you will need to use the sawsall on the ones that you loosened already.
#14 |
He's not going to be able to break them off if the square part of the carriage bolt is spinning in the bed floor. You don't need air tools. Just go buy you a cheap electric grinder if you don't have one.
#15 |
The square part of the carriage bolts wont spin in the floorboard if the bolts aren't loosened.
#16 |
bring it over i'll take it off for you, i need another one anyway
common sense isn't so common anymore |
#17 |
Hunting is Life
i tried a 18 volt cordless sawsall, i tied to cut the cross membersthat attach the bed to the frame, but no luck so i am going to try a cutting tourch.
pat
#18 |
cut an X in the top of the bolt and chisle it off !
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
