Old 10-15-2007, 10:44 AM   #1
Mickey_D
Dirteh Kitteh
Mickey_D's Avatar
What would be the differences?
I've located a fairly straight donor body for my old '81. It's a 1983 GMC Sierra Grande.
It's got a little rust around the rear fenders, and some surface rust on the roof. The rest of the cab is in fairly good shape with the exception of the door skins. Both sides look like they were mule-kicked shut by someone a little over-exuberant. But the rocker panels and the cab corners are still intact, which is a rarity around here.
So here's my question : Are there going to be any differences in how the body bolts to the frame? The donor is a 2WD ex-Diesel (converted to gas a long time ago) and mine is a 4WD gas. The donor is missing the engine and tranny (and the master cylinder ).
Am I going to run into any problems with this being a direct swap? Or am I going to (for once) have a fairly easy time of it?
Darrin
1955 Willys CJ-5 all original and the oldest CJ-5 on the road.
2001 Dodge Neon (wife's car)
1995 Jeep Grand Cherokee Limited Edition SOLD
1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD
1993 S-10 4X4 Tahoe SOLD
Sign up with the Contact List
RIP ESLL
Mickey_D is offline   Reply With Quote
Old 10-15-2007, 01:17 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: What would be the differences?
Check the trans tunnel in comparison. The 4x4 will have a high tunnel. Other than that, it will be the same.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 10-15-2007, 02:13 PM   #3
Mickey_D
Dirteh Kitteh
Mickey_D's Avatar
So I might need to beat the snot out of the mid section of the floor boards? I know I'm going to need to cut a hole for the transfer case shifter....
Hrm, bodywork by Sawzall.
Darrin
RIP ESLL
Old 10-15-2007, 04:34 PM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
you will have to cut the floor and put in the higher tunnel if memory serves me correct
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 10-15-2007, 09:23 PM   #5
Captkaos
Captkaos's Avatar
If the donor doesn't have a high tunnel, you will need to remove that section that differs from the 4x4 truck and weld it into the donor. The other alternative is a body lift...
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 10-16-2007, 06:43 AM   #6
Mickey_D
Dirteh Kitteh
Mickey_D's Avatar
I think this is how I'll go. Considering I'll already have the body off.
Will a 2" be sufficient you think?
Darrin
RIP ESLL
Old 10-16-2007, 10:59 AM   #7
Roper
On my 81 4x4 the transmission hump on the floor board looks like it is bolted in place. Im thinking just un bolt the hump from your 4x4 and use it to replace the hump on the 2 wheel drive cab.
Roper is offline   Reply With Quote
Old 10-16-2007, 03:13 PM   #8
ChaseDale3and8
ChaseDale3and8's Avatar
Some of them were bolted in on the 4x4s. The 2wds that I have seen are low hump one piece floorpans except the ones that had a 4-speed transmission.
I'm pretty sure that those were the only 2wd cabs that had a bolt in center section.
You would need to unbolt the midsection out of the 4x4, place it in the 2wd cab, mark around the outside of it, and then do your cutting on the inside of your line. A little measuring and cutting, but not really a big deal to do. You could even get some J-nuts and drill your holes and bolt the section back in, which is what I would recommend to do. That way if you ever needed to remove it again, it would just be a bolt in and out deal. This really helps in the case that you have a 4-speed trans and ever need to pull it back out. ...Joe
I'm not speedin'! I'm qualifyin'!
ChaseDale3and8 is offline   Reply With Quote
