Old 10-15-2007, 12:11 PM   #1
tk1251k
tk1251k's Avatar
oil pressure switch
Where is oil pressure switch located on 1972 gmc 350 engine. I have a bad leak from top back side of engineseems to be coming from behind coil and running down transmision a real bad leak. Never changed switch so I think it might be there. thanks terry
tk1251k is offline   Reply With Quote
Old 10-15-2007, 12:23 PM   #2
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Re: oil pressure switch
there's not a switch on a 72 it is a direct line hook up to the block behind the dist.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 10-15-2007, 12:50 PM   #3
tk1251k
tk1251k's Avatar
Are they bad to leak and can you get one at advance.terry
Old 10-15-2007, 01:01 PM   #4
tk1251k
tk1251k's Avatar
The ones I have found have electrica hookup but has an oil line into it.
Old 10-15-2007, 01:04 PM   #5
1966gmc
Why does it taste purple?
1966gmc's Avatar
Just buy a mechanical oil pressure gauge line kit.Should come with the fittings and new plastic/copper line.I had the one on my El Camino blow out driving down the road and lost all 5 qts of oil within seconds.
1966gmc is offline   Reply With Quote
Old 10-15-2007, 01:07 PM   #6
tk1251k
tk1251k's Avatar
Yea mine just started leaking thought was rear seal . I think it must be sender. Thanks terry
Old 10-15-2007, 03:39 PM   #7
rick0312
rick0312's Avatar
my mechanical oil gauge was leaking where it screws into the block just behind the dizzy, so i bought a kit at autozone; replace with new fitting an no more leaking.
rick0312 is offline   Reply With Quote
Old 10-15-2007, 09:57 PM   #8
llama
Do some have a oil line and an electrical connections? What is the electrical connections for with the oil line?
llama is offline   Reply With Quote
Old 10-20-2007, 07:10 AM   #9
llama
ttt
