Old 10-15-2007, 12:49 PM   #1
RedZ71
Junior Member
RedZ71's Avatar
removed gauge cluster, had to cut oil pressure connection
so how screwed am i? this wasnt a wire... it was some sort of metal tube or something. where can i get a replacement? will one come with a new guage cluster when i buy it?
(unfortunatly, it wouldnt come loose, and the torque was just bending the guage housing anyway, so i jsut snipped it off)
Jonathan
2001 ECSB Silverado Z71
1971 LB C10 Custom
www.z71silverado.com
RedZ71 is offline   Reply With Quote
Old 10-15-2007, 01:01 PM   #2
1966gmc
Why does it taste purple?
1966gmc's Avatar
Re: removed guage cluster, had to cut oil pressure connection
More than likely it was a copper tube.You can buy that stuff at a local hardware store or buy it as a kit upgrade for your new gauge.Your new gauge probably will not come with the tube.You will have to solder it together.Not hard at all.Just make sure it dont leak afterwards or you will have a big mess in the cab
1966gmc is offline   Reply With Quote
Old 10-15-2007, 01:08 PM   #3
RedZ71
Junior Member
RedZ71's Avatar
haha yeah, i was wondering if it was going to start leaking oil... but it looks like it was pinched pretty good by my sidecutters
whats the tecnical name for that, so i know what to look for?
Jonathan
1971 LB C10 Custom
Old 10-15-2007, 01:10 PM   #4
1966gmc
1966gmc's Avatar
It should be a mechanical oil pressure gauge copper tube kit if you are goin to buy it at a parts store or out of a catalog
Old 10-15-2007, 01:42 PM   #5
67ChevyRedneck
67ChevyRedneck's Avatar
Don't start the truck without pinching off that line.... trust me, I know this
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-15-2007, 01:51 PM   #6
fun in dirt
fun in dirt's Avatar
...and you can't hold your thumb over the end just to pull it back in the shop either!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 10-15-2007, 01:57 PM   #7
1966gmc
1966gmc's Avatar
Very true.....especially with a HV oil pump lol
Old 10-15-2007, 02:00 PM   #8
67ChevyRedneck
That's actually what I tired... all I had to do was move the truck 20'
Good thing it got all over the rubber mats and not my new carpet
Jesse James
Project "On a Dime"
Old 10-15-2007, 04:02 PM   #9
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
All you need are a couple of high pressure fittings to reconnect your tubing to your oil gauge. I usualy buy mine from a Mack Truck dealer as you can just put togrther what you need. You can probabaly get a new fitting for the back of your gauge as well. Cheap! There is usually more copper tubing then the required length needed to hook up your gauge. Pull a bit through your fire wall and bobs your uncle.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 10-15-2007, 04:16 PM   #10
Andy4639
Old member
Andy4639's Avatar
Buy brass fitting at the local hardware store and reinstall. Nothing to it. I don't trust the plastic tubing you get with new gauges like the plastic tubing for a ice maker.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 10-15-2007, 05:08 PM   #11
jorgensensc
jorgensensc's Avatar
I bought the copper tube at the auto parts store for mine. Worked great! I just coiled the excess in the engine compartment similer to stock. Definately stay away from the nylon stuff.
SHawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 10-15-2007, 05:49 PM   #12
msgross
msgross's Avatar
me too!
It should have one more connection behind the distributor before it passes through the firewall. Mine had a coiled one coming out of the engine then another 18" one onto that for the gauge (the one you cut).
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
