Old 10-15-2007, 12:56 PM   #1
burnitdown612
computer question
I was wondering if the computer from my 87s 305 motor incompatible with a350 out of 89 fullsizeblazer. The motor instalation is compltete but the truck just will not run right. I double checked all theplug wires and even did a timing check on it and everyhitng is perfect. The distributer cap and rotor and plugs are all brand new. It runs good at ittle but once you give italittle rev it turns into a flame thrower. i have a feeling the 305 ecm does not allow ittopump enough gass to satisfy the engine. any help would be great - nick
1987 k10 silverado 305/700r4
burnitdown612 is offline   Reply With Quote
Old 10-15-2007, 01:08 PM   #2
1966gmc
Why does it taste purple?
1966gmc's Avatar
Re: computer question
Are you talking about flames coming out of the carb? If so,you are back-firing thru the intake.That would be a timing problem more than likely.Does your current distributer have a big 4 pin connector coming off the side of it? If so I would replace it with one that is not computer controlled.
1966gmc is offline   Reply With Quote
Old 10-15-2007, 01:49 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
The computer is the same, but the chip isn't. If it is backfiring though the TBI, check you timing. It nees to be set with the bypass disconnected. Running with it connected you should have about 15 degrees.
DON'T replace the computer controlled distributor, the ECM relies on it to control you timing.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 10-15-2007, 02:01 PM   #4
1966gmc
1966gmc's Avatar
See I bypassed the ECM on my Elky. Thats why I said something about the cc dist. I'll stick to vacuum advance over computer controlled advanced any day. I want to tell the car what to do,not the computer
Old 10-16-2007, 01:27 AM   #5
rfmaster
rfmaster's Avatar
Hmmmm. Only if you knew what you are missing....
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
