Old 10-15-2007, 08:45 PM   #1
roughedup72
roughedup72's Avatar
What cam are you using???
Hey Yall, I got the engine torn down and am in the process of getting the parts to put it back together. I was wondering what cam are yall using and how do you like its performance. I am looking for something to give me more out of the hole and still have a little left. I've got 3:73's a 700r4 and a 350 4bbl with headers and 2.5" exhaust. I'm also running 285/70/15 tires. The engine has been bored .30 over and may be going to .40 over if I cant hone out some of the fine grooves in the cylinders. SO suggestions would be greatly appreciated. Thanks in advance for your help.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod.
roughedup72 is offline   Reply With Quote
Old 10-15-2007, 10:18 PM   #2
68Stepbed
68Stepbed's Avatar
Re: What cam are you using???
I'm running a COMP XE262. It has a slight thump at idle and pulls pretty hard from about 2500-5500 rpm. I would liked to have gone to the XE268, but would've had to change the valvesprings, which turns out, needed to be changed anyway.
I've heard the Lunati VooDoo cams have some good profiles.
Depending on budget, you simply can't go wrong with a hydraulic roller setup. They cost more, but you get what you pay for.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 10-16-2007, 02:20 AM   #3
bayer20
For bottom end I would suggest, EDLBROCK RPM Intake, K&N Large Air Cleaner, 1 5/8 Primary Tube Long tube Headers, Comp Cams 270H 1800-5800rpm, 2000 Stall converter (Jegs $100), good wires and plugs. Your Engine is an Air Pump...What goes in must come out. Also A nice Posi Differential if you don't already have it. If you even want to go further than that, a good pair of Vortec Heads will add a bunch of torque as well.
There is no replacement for displacement!
bayer20 is offline   Reply With Quote
Old 10-16-2007, 02:24 AM   #4
bayer20
As a matter a fact the above mentioned setup including the Vortec heads got me 400 horse and 420 ft.
Old 10-16-2007, 02:36 AM   #5
Billla
Billla's Avatar
CR and heads?
Can't talk about cams without knowing the engine configuration...
Billla is offline   Reply With Quote
Old 10-16-2007, 05:39 AM   #6
earl87gta
earl87gta's Avatar
Im using a gm lt4 hot cam kit I like it and I have over 400 HP with vortec heads. the kit also comes with 1.6 roller rockers.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 10-16-2007, 09:17 AM   #7
Jcentsr6
Junior Member
Jcentsr6's Avatar
Lunati cam and lifter
going to sell this one...looking for a SWB project next.
Jcentsr6 is offline   Reply With Quote
Old 10-16-2007, 11:03 AM   #8
BurnoutNova
BurnoutNova's Avatar
XE294 in my nova
BurnoutNova is offline   Reply With Quote
Old 10-16-2007, 12:03 PM   #9
mark's68
comp cms 4x4 extreme 270 in a 388. lots of torque.
mark's68 is offline   Reply With Quote
Old 10-16-2007, 01:52 PM   #10
The Big Green
I have 11.1 pistons and I have the comp 305dur/325lift cam. Let us know what you want your rpm pulling range to be. It is stall speed, cam, and intake are some. Match everything perfect on the lower rpm along with a good stall speed you can shoot out of the hole like a rocket...lol
The Big Green is offline   Reply With Quote
Old 10-16-2007, 02:02 PM   #11
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Lunati VooDoo. You couldnt give me a Comp, sorry , had a real bad experiance with them
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 10-16-2007, 02:05 PM   #12
The Big Green
1970 CST Short Wide
Let us know, I want to keep this truck going for awhile with no problems. My first comp cam and always went lunati myself.
Old 10-16-2007, 02:42 PM   #13
bayer20
Lunati, Comp Cams...It really doesn't matter what name brand but more so the Spec of the cam. All I can say you better pre-lube it or you will brake of a lobe off, no matter who makes it.
Old 10-16-2007, 06:04 PM   #14
bad6772
Official Site Guitar Shredder
bad6772's Avatar
stock ZZ3 < complete roller with 3000 stahl.........
bad6772 is offline   Reply With Quote
Old 10-16-2007, 08:50 PM   #15
BCOWANWHEELS
I,d Install A Stock Gm 350-350 Hp Lt1 Cam & Springs. Its Just 89.99 From Chevy.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 10-17-2007, 01:11 AM   #16
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Arrow Re: What cam are you using???
WOW, thats my enginge. With the exception of a recent change from Headman long tubes to Sanderson 3/4 headers. Upgrading wires in near future. I have a posi as well.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 10-17-2007, 02:11 AM   #17
BurnoutNova
theres only like 2 major cam grinders in the country... all the companys go though one of them, comp, lunati, crane, ect. atlest thats what ive heard
i like the comp cam i have, it idles like crap (almost doesnt idle actully) but it freaking screams between 6000 and 7800 rpm. freaking thing shounds like a sprint car with it, and having open headers
Old 10-17-2007, 02:13 AM   #18
BurnoutNova
thats the magnum 305H grind. i had that in a 355 once good cam but really old technology. ive heard alot of good things about the new voodoo cams, and want to try one when i put the 302 together for my nova, bout .650" solid roller of course
Old 10-17-2007, 09:51 AM   #19
1970 CST Short Wide
Senior Moment
My problem with Comp is there warrantee department. I had a problem with one of there cams and was treated like I didn’t know anything about anything by there rep , his name was "RED" This jerk told me that if I didn’t like what he was offering I could eat
sh!t and die. I wont deal with people who treat there customers like that. When I changed to the VooDoo the loud slapping of the steep ramp that Comp likes went away and I’ve been happy ever since
Pittsburg Ca
94565
Old 10-17-2007, 11:48 AM   #20
Frizzle Fry
Frizzle Fry's Avatar
One more vote for voodoo. I have one in the 476. Very pleased with it... after switching from a comp.
Frizzle Fry is offline   Reply With Quote
Old 10-17-2007, 12:11 PM   #21
bigfredtn
Active Member
Location: West TN (Memphis area) now. East TN (my favorite place to live).
I have COMP XE294 in my truck.
BigFredTN
70 chevy stepside 350 with some goodies inside, turbo 400.
69 Chevy long wheel base. Dad bought new in 1970
62 Chevy Impala
98 GMC Yukon
1970 Ford Mustang Fastback I know its a Ford.
bigfredtn is offline   Reply With Quote
Old 10-20-2007, 10:45 AM   #22
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
I’m using Lunati voodoo cam w/ lifters & springs. It’s not together yet, so no info on how it runs….But I hear its awesome.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 10-20-2007, 03:50 PM   #23
BCOWANWHEELS
for the best cam call this guy. he custom grinds cams specifically for your engine setup, vehicle weight, r&p ratio, and trans being used. he also regrinds and hard faces cams all on a computer controled machine. nothing like a custom made cam just for your project.
bob
his name is steve bemos
ph.#
1 706 340 6914
Old 10-20-2007, 04:47 PM   #24
BurnoutNova
i heard its not that much more expensive to have cams custom ground, only like 25$ more than a production grind. a friend of mine goes through ISKY for his sprint car cams, really likes them i guess
Old 10-20-2007, 05:31 PM   #25
eedgell
It's the air up here
eedgell's Avatar
I guess a little off the wall for this board, but I have had good luck with ISKY's MEGA cam line up. Good selection for both SB, and BB. The best out of the hole, to top end power band I have found. Real smooth, and powerful. Give them a look.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
