Old 10-15-2007, 09:55 PM   #1
Exhaust Through Crossmember Q?
What`s the best way to run the exhaust through the trailing arm crossmember?What size pipe do you use,4"?Can I get measurements on locating the wholes?
I have a rolling frame and would like to do this before I mount the motor and trans.While the trans get`s rebuilt.
Old 10-15-2007, 10:21 PM   #2
matthufham
Re: Exhaust Through Crossmember Q?
same question on the 4 inch, 1/4" steel pipe.
matthufham is offline   Reply With Quote
Old 10-16-2007, 12:56 AM   #3
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
special-k,
Take a look at the FAQ on shortening my frame. You don't really need pipe to do it. My exhaust pipe is 2.5", and I cut a piece of flat plate with a hole 3" ID and 5" OD. Use the ID as a template and cut it where it fits the best.
*** Hmmm, alot of pics are missing from my FAQ, so here is one from my build thread. You can see it pretty clear on the right hole.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 10-16-2007, 05:47 AM   #4
Thanks.I like how your pipes are run over the axle and to the outside of the frame.I have some pipe,so I figured I`d use that.This is "the way" to run pipes on 2wds.I want to do this while I can still move my frame around outside before winter.Once I get the M22 rebuilt and motor/trans set it`s exhaust time.Maybe by spring I`ll be setting the cab on.
Old 10-16-2007, 09:05 AM   #5
glock35ipsc
Running them over the axle then outside the frame was a necessity since I am using a Blazer tank. Your right, this is the "only way" to do it on a 2wd, as there is nothing hanging below the frame.
Bob
