Old 10-15-2007, 11:24 PM   #1
exbbcoach
exbbcoach's Avatar
Battery Box Replacement
I just got a new battery box for my 72 Cheyenne. I am having trouble getting the old one off. Is there a secret or do you just have to squeeze in next to the radiator. Anybody?
Coach:
exbbcoach is offline   Reply With Quote
Old 10-15-2007, 11:55 PM   #2
longhorn70gmc
longhorn70gmc's Avatar
Re: Battery Box Replacement
I removed my auxilery battery tray by removing nothing but bolt screws. I figure the main battery tray is the same. I have a longhorn, so I have two tray's. Good Luck on yours. I will be doing the main tray soon enough.
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Old 10-16-2007, 08:12 AM   #3
chris71
chris71's Avatar
Coach:
dont forget the one bolt from the tray to the inner fender, i didnt see it due to crud and ran into the same problem. ounce you get that off and the 6 or so bolts to the core support it should just come straight up. good luck
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
Old 10-16-2007, 10:59 AM   #4
kwmech
Coach:
If you have the large radiator, then what I do is loosen the radiator so I can squeeze a ratchett in between to get the 3 bolts down the side. Don't have to drain it just jack it to the side some.
Old 10-16-2007, 11:06 PM   #5
exbbcoach
exbbcoach's Avatar
Thanks guys---the bolt to the inner fender is stripped I guess. Wont come out, jsut turns. Probably will just cut it off.
I do have large radiator. Can you just loosen one side?
Coach
