Old 10-16-2007, 07:04 PM   #1
crawdad
crawdad's Avatar
Question Question about wiper motors or switch???
I can't get the wipers on my truck to come on. When I turn on the switch (column mounted), I can hear the motor working and the wipers will move a little bit and then stop and start making a grinding sound. If I leave the switch on and get out and pull on the wiper arm a little bit, the blade will come all the way up and back down and then hang up again. Does this sound like a bad wiper motor or what? Any ideas? Thanks.
2012 Silverado LT 1500, 5.3, 6 speed auto
'86 SWB C-10 Silverado
crawdad is offline   Reply With Quote
Old 10-16-2007, 07:48 PM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: Question about wiper motors or switch???
Most common thing to go out on these old trucks is the wiper motor.
However you may want to remove the cowel coer and take a look at the linkage to make sure it's still all good and tight especially where the linkage mounts to the motor. if any of it's worked it's way loose then tihten it all up and check it out.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 10-16-2007, 08:44 PM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
could be the cog on the motor that has a stripped tooth or two too . pull the cowl and make sure it looks workable then go for the motor. you can disconnect the arm linkage and see if it works that way but it may need the load of the arms to fail
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
