Old 10-16-2007, 08:28 PM   #1
Smokediver153
What wire go to the front turn signals
OK here goes the PO put a 72 grill on a 69 truck C-10. I put the right grill back on and now I have to wire the turn signals and I have only one wire going to the turn signal but the light has two wires I need help......
Thanks in advance
Paul
Smokediver153 is offline   Reply With Quote
Old 10-16-2007, 08:40 PM   #2
cdowns
cdowns's Avatar
Re: What wire go to the front turn signals
driver side should be a light blue and a brown and pass side dark blue and brown if its the same as 71trucks// the browns are running light and blues are signals
Old 10-16-2007, 10:01 PM   #3
71tahoe
71tahoe's Avatar
If they didn't change the connections in 72 they should plug right in. I have a 71 with 69 lights and the factory plugs worked great.
Sounds like the PO hacked up the wiring pretty good. Go with cdowns suggestions for redoing it.
71tahoe is offline   Reply With Quote
Old 10-16-2007, 11:11 PM   #4
Smokediver153
Thanks for all the help I will try and search the wire down after work tomarrow....
Thanks Paul
