PTO anyone
I have an old pto , bolts to side of sm-465 tranny. Does anyone have one of these setups. Any suggestions , good and bad. This thing could power a mega winch.
Re: PTO anyone
I have one that used to run a drill rig, I am not sure where I am going with it.
Maybe hydraulic???
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars ![]() |
Re: PTO anyone
PTO winch hiden behinde the front bumper. Thats what I want to do I f I can find one for a 205 transfer case or a NV4500 trans
Earl 68 2500 4x4 GMC Burb |
Re: PTO anyone
I`m a big pto winch fan.I like running my winch with small block power!!
Re: PTO anyone
It would run a PTO winch, but you would have to have the tranny in neutral and modulate the line speed with the throttle.
The best set up would be to find a PTO that runs off of the transfer case, so you could use gears to change line speed, and could still drive if needed. You could also use reverse to spool the cable back in. Of course, there are some reversible PTO's, but they are harder to find.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
Re: PTO anyone
Or hydraulic off the PTO and a Hydraulic winch because they are cheap and easier to route than driveshafts.
Also you would have the option of swapping the winch to the back when you get the urge to winch in reverse.
Hunting is Life
Re: PTO anyone
i have a sm465 in my 3/4 ton how do i know if i have a pto.
pat
1970 GMC K-1500 4x4 292 I-6 3 on the tree-prodject truck ![]() 1971GMC 2500 2wd 350-v8 sm465 4spd-parts truck ![]() 2005 Ford Ranger 4.0/5spd auto 4x4 extended cab--everyday driver bought new ![]() ![]() |
Junior Member
Re: PTO anyone
I have a PTO winch on my truck and I can tell you it's a "hoss" of a winch setup. I have used it several times but you know when you it's hooked up, something has to give!! 1969 GMC is right, you can operate it at different line speeds depending on what gear you have the transmission in. Also the rpm's of the motor. I also have a manuel throttle which helps to keep rpm's constent. Here's some pics. Randy
1972 GMC K2500, stepside, stock 350, 4 speed. Former F/D truck with 32,000 miles, no rust. 1973 Jeep CJ 5, 304, 33's with side pipes 2008 GMC 2500HD, CC, SWB, D/A, SLT |
Re: PTO anyone
My pto was setup for hydraulic dumptruck. Just gotta find a winch.
Re: PTO anyone
The guy I got my trans from had a PTO for it and I decided not to get it at the time it was a hydraulic pto. i wish I would have got it now.
