Old 10-16-2007, 10:06 PM   #1
tcb-1
Nothing to see here.....
tcb-1's Avatar
Question about Drop Spring Installation......
got a set of used 2/4 coils for my 69 swb stepside. installed the rears tonight and only got around a 2" drop. question: is there a correct direction to install the rears?
sooooo, is the tighter coil length on the torsion bar side, or the frame side. any pics? need help.
thanks guys!
tcb-1 is offline   Reply With Quote
Old 10-16-2007, 11:00 PM   #2
SactoJim
SactoJim's Avatar
Re: Question about Drop Spring Installation......
I don't think it matters.....least it didn't for mine.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 10-16-2007, 11:26 PM   #3
clemson71guy
clemson71guy's Avatar
this is a 2/4 drop and i dident put them in any specific way...hope it helps
clemson71guy is offline   Reply With Quote
Old 10-16-2007, 11:32 PM   #4
67_C-30
I have a radical idea!
67_C-30's Avatar
thanks guys!
What brand of springs did you buy?
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 10-16-2007, 11:34 PM   #5
powell72
powell72's Avatar
The pigtails should be the same on both ends of the spring. Were you able to bolt both ends of the spring in?
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 10-17-2007, 07:47 AM   #6
tcb-1
tcb-1's Avatar
need to find out (if possible) the make of the springs.
the pigtails fit inside the spring clamp plate completely, so no issues there. it's buttoned up and setting on the floor, but seems a bit high still.
try to get pics tonight.
Old 10-17-2007, 07:58 AM   #7
cdowns
cdowns's Avatar
40 year old springs tend to sag so the amt of drop wont be exact
Old 10-17-2007, 08:07 AM   #8
tcb-1
tcb-1's Avatar
cdowns,
the springs I put on were practically brand new.
before I installed these spring, I measured to the top of the rear fender opening. I was exactly were LMC said I should be, 34". now it's 32" with the springs on.
Old 10-17-2007, 08:15 AM   #9
70c10
67-72 Addict!
70c10's Avatar
Those say Belltech 5354 which according to their site is a 4" rear coil spring. Another thing to consider is the person you bought them from may have accidently ordered 2" rear drop springs.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-17-2007, 02:36 PM   #10
67_C-30
67_C-30's Avatar
Those are not his springs...
My trucks
Old 10-17-2007, 02:45 PM   #11
70c10
67-72 Addict!
70c10's Avatar
67 c-30, sorry about that. In my haste I thought YOU were asking what brand of springs they were in the pic. I misread your post!
Jim
Old 10-17-2007, 05:57 PM   #12
67_C-30
67_C-30's Avatar
No problem, I'm guilty of that myself!
My trucks
Old 10-20-2007, 09:52 AM   #13
70 net440
Junior Member
70 net440's Avatar
I put some 2" drop springs from LMC on my son's '67 and got almost zero drop from stock. But at least the ride is extremely harsh. I just got done putting an ECE 2.5/4 drop kit on the wife's '63 and got almost 3.5 inches of drop in the rear, and the ride is great.
63 C10
70 Coronet R/T
67 C10
70 Dart Swinger
71 K10
70 net440 is offline   Reply With Quote
