Old 10-17-2007, 11:02 AM   #1
Stepside65
Still Truckless!
Stepside65's Avatar
Need help asap
Having problems with removing a gas tank. I unbolted the straps in the front and disconnected the fuel sending unit. I tried to move it and it won't budge. What else holds this darn thing in. Need advice before tonight when i go back to work on the truck.
~James
Truckless
2009 Hyundai Sonata<~~Wife's sedanomatic
1997 Nissan Pickup Father-in-law's tonka toy I am forced to drive
Founder of The 60-66 Club
Tutor Et Ultor
Stepside65 is offline   Reply With Quote
Old 10-17-2007, 11:13 AM   #2
jchav62
1962 C-10
jchav62's Avatar
Re: Need help asap
Did you loosen the clamp at the filler neck?
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 10-17-2007, 02:22 PM   #3
joehalford01
joehalford01's Avatar
Re: Need help asap
I just did this
there are four small bolts on the bottom of the tank holding it down. I believe they are 1/2". Mine were covered in crud and very hard to see. They are also near impossible to get to. I think i'd kill myself if i had worked on an assembly line back in the day and had to install these four bolts all day.
joehalford01 is offline   Reply With Quote
Old 10-17-2007, 02:44 PM   #4
Tim64
Tim64's Avatar
Re: Need help asap
All my 63 has is the strap bolts and the filler neck clamps. I took the seat completely out, and it wasn't a bad job.
Good luck.
Tim64 is offline   Reply With Quote
Old 10-17-2007, 04:07 PM   #5
jchav62
1962 C-10
jchav62's Avatar
Re: Need help asap
Good luck.
That's all my 62 had too...
Joseph Chavez
Old 10-17-2007, 05:48 PM   #6
Stepside65
Still Truckless!
Stepside65's Avatar
Re: Need help asap
Thanks yall for the quick assist. I'll give it a shot tonight.
~James
Truckless
Tutor Et Ultor
Old 10-17-2007, 06:10 PM   #7
62 short step
62 short step's Avatar
Re: Need help asap
Same here for a 61.
62 short step is offline   Reply With Quote
Old 10-18-2007, 01:00 AM   #8
62ChevyStep
62ChevyStep's Avatar
Re: Need help asap
Originally Posted by 62 short step View Post
Same here for a 61.
Ditto!
________________________
62' 3.5/5 drop SWB Fleet, PS, PB-Dsk/Drm,350/700R4
08' Chevrolet Silverado CrewCab
05'Toyota Tacoma Prerunner SR5
62ChevyStep is offline   Reply With Quote
Old 10-18-2007, 08:35 AM   #9
tompotts
TowMater
tompotts's Avatar
Re: Need help asap
I remember that my tank was stuck and I had to bump it to get it to pop out but it only had the two straps. 64 long/fleet.
Don't take life too seriously, you'll never get out alive.
tompotts is offline   Reply With Quote
Old 10-18-2007, 02:11 PM   #10
joehalford01
Re: Need help asap
that's lame, i wonder why i had four bolts holding it down? i wasn't on drugs so i know they were there.
Old 10-18-2007, 05:08 PM   #11
badriand
badriand's Avatar
Re: Need help asap
Had 2 also, the biggest pain for me was getting the angle right to lift out.
badriand is offline   Reply With Quote
Old 10-18-2007, 06:13 PM   #12
65chevy4x4
Re: Need help asap
Hope You Drain The Fuel Out Of The Gas Tank,it Can Be Very Heavy If You Don"t
65chevy4x4 is offline   Reply With Quote
Old 10-18-2007, 07:57 PM   #13
Greg63
Enjoy your truck
Greg63's Avatar
Re: Need help asap
Maybe you are looking at the four bolts that secure the gas tank mount to the floor ?
The two floor mounted tank mounts are bolted to the floor by four bolts and the backside of the mounts are spotwelded to the back wall of the cab . The gas tank straps go over the tank and bolt down with two long bolts that thread into the floor mount .
I removed my cab mounted tank when I put the poly tank under the bed . I went to remove the floor mounts so I could make up a utility/speaker box where the tank used to be in the cab , and found out that the gas tank mount was bolted and welded down on my '63 .
Make sense ?
Greg
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 10-19-2007, 07:04 PM   #14
joehalford01
Re: Need help asap
Make sense ?
Greg
that could be it, it wouldn't budge though until i undid those bolts, of course, if the mounts were moving around it would probably have been easier to move and it was full of gas and it was nighttime, and i have not been out there since as i had to close up my project for the night and do some other stuff....
i'll look at it the next time i'm out there
