Old 10-17-2007, 03:13 PM   #1
brossow
Amateur Rust Fighter
brossow's Avatar
Question Difference between '63-70 and '71-2 spindles?
Just discovered that the drop spindles I had been planning to use on my '72 C/10 are listed as '63-70 only and there's a different part number for '71-2. Anyone know what the difference is? I've got two sets of drop spindles that had been purchased for my '64 and '66 projects and had planned to "steal" one set for use on my '72 instead, but apparently that can't happen.
Thanks for any info,
Brent
Brent
'72 Chevy SWB stepside - [ Build Thread ]
'79 ChevMC SWB fleetside - [ Build Thread ]
'64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...)
brossow is offline   Reply With Quote
Old 10-17-2007, 03:27 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Difference between '63-70 and '71-2 spindles?
Upper and lower balljoints are different as are the outer tie rod ends. You can probably switch to '70 ball joints and tie rods to make them work. My suggestion would be to save them and get the correct '71-'72 spindles.
Keith
Convert to disc brakes.
Old 10-17-2007, 04:38 PM   #3
bigtruck81
pre 70 are drum brake, so no provisions for your calipers.
bigtruck81 is offline   Reply With Quote
Old 10-17-2007, 06:14 PM   #4
brossow
brossow's Avatar
I'm talking about the aftermarket drop spindles, which are all set up for disc brakes (as far as I know — maybe there are drum brake drop spindles out there, too).
Brent
Old 10-17-2007, 06:22 PM   #5
brossow
brossow's Avatar
Excellent info — THANKS! Sure hate to spend more money on spindles as it's really tight already, but I'll keep my eyes open for a good deal from someone abandoning a project or looking to trade for the earlier style. Or, since I'll be changing ball joints and tie rods anyway, maybe I'll just get the earlier stuff if that'll work.
It's only money, right?
Thanks again,
Brent
Brent
Old 10-21-2007, 07:26 AM   #6
canadianredneck
i put a 71 front end under my 68, had to swap balljoints, all tie rods and steering ard to make it work
canadianredneck is offline   Reply With Quote
