10-04-2002, 09:34 PM | #1 |
Wire looms
The other day I bought a new chrome engine dress-up kit and included were two four-hole spark plug wire separators. No instructions were included, so where exactly do these go? I have the stock manifolds. I am going to get new wires too, so I could get actual wire looms if I need those at the same time. Pics would be appreciated.
Thanks, John
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
10-04-2002, 10:16 PM | #2 |
Usually those are designed for the valve cover bolts and the log style manifolds that run UNDER the plugs. I like the Made for You (that'st he company name) vertical looms and I bolted them to the oil pan in an arrangement that worked for me. I have two of these setups, one on my Camaro and one on the Jimmy. I buy Taylor pre-made plug wires for a 67-72 V8 truck.
10-05-2002, 02:50 PM | #3 |
Thanks. Is that called the Made for You vertical wire loom? I was researching them at Summit.
10-05-2002, 05:01 PM | #4 |
Yup. They aren't cheap, but I like having the wires out of the way. Work great with rams horns or headers, but won't work with log style manifolds.
