Old 10-17-2007, 10:05 PM   #1
myersjeremy
myersjeremy's Avatar
Transfer case leak??
Got a 85 Silverado 4X4 that loses its tranny fluid and stops pulling but if you let it sit a while and check majority of the fluid is back and it will pull again. What are some things to look for as far as with the transfer case? Is there a way to tell if it is forcing the fluid into the transfer case? Is there an overflow tube because I am getting quite a bit of fluid coating the underside but can't pinpoint the leak. It is definitely not the trans front seal.... Thanks for the help!
Jeremy
myersjeremy is offline   Reply With Quote
