10-17-2007, 10:56 PM | #1 |
Slugish
feel stupid but need advice
went to the strip last fri. night.
drove my 84 there ,1.5 hrs away . changed to drag radials once Igot there. ran only 2 passes / drove back home . went to change back to my street tires when Igot back home noticed on driver side there was no brake drum . Had run on the strip & back home with no brake drum on 1 side drum had come off when Ipulled street tire of / & Iput drag radial on without even realizing what Ihad done. bought new drum from Advance // cant get it on / tried everything / adjustment screw all the way loose . any help would be appreciated Dumb Ass from Va. |
10-17-2007, 11:28 PM | #2 |
Re: feel stupid but need advice
You probably pushed the rods out of the wheel cylinders, and there caught on the cylinder housing, not allowning the shoes to go all the way back in. Hopefullly you didn't push the seals out of the wheel cylinder, however I am sure you did. Probably time for a new wheel cylinder, shoes, and hold down kit in the rear
Duro
-1986 K10 LWB, 350 HD,TH400 3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires All original, second owner truck -1979 Monte Carlo, 350, 200r4, 3.73 posi -1987 GT T-top Mustang - slow moving project |
10-18-2007, 11:05 AM | #3 |
www.73-87chevytrucks.com
What do the actuators (pins) in the wheel cylinder look like? Are they still there in the cylinder? IF they are ok, you can get them back in by relieving pressure off the bleed screw. I would inspect everything to make sure nothing is broken or destroyed before reassembling it.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
10-18-2007, 07:28 PM | #4 |
Robert Olson Transport
youre lucky if the wheel cylinder didnt come apart and you would ahve lost pressure to the rear brakes that coulda been hairy if you needed to stop quick
10-18-2007, 08:23 PM | #5 | |
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD |
10-19-2007, 03:49 PM | #6 |
Slugish
tHANKS FOR THE RESPONSES.
Will check what yall said. every thing looke normal & dry . If pin had come out of wheel cylinder would it not be wet with brake fluid ?the adjuster is srewed all the way down , in fact its out of the slot & drum still does not fit . Will keep trying . Maybe letting pressure out of bleed screw will work . |
