Old 10-18-2007, 12:06 AM   #1
salazar44
65 - Chevy C10
salazar44's Avatar
stock fuse panel
Unfortunately time has put some wear on the white lettering on my fuse panel. Can any please break it down what it says? I would like fuse amp ratings for each slot and what its for.
the lowest slot only has one fuse holder. the holder on the right is missing. I wonder if this is causing any of my problems.
i pulled out EVERY fuse one at a time and my volt gauge still stood in the middle.
VIC
One Repair Leads to Another!
http://vix65chevyc10.blogspot.com
salazar44 is offline   Reply With Quote
Old 10-18-2007, 12:09 AM   #2
64GMCHorsepower
Justified!
Re: stock fuse panel
I know I posted a pic of one a while back, let me look....
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 10-18-2007, 12:12 AM   #3
64GMCHorsepower
Justified!
see if you can read these......
one more....
Chad
Old 10-18-2007, 12:56 AM   #4
salazar44
65 - Chevy C10
salazar44's Avatar
Chad... Thats awesome! Thanks so much. I notice your lowest fuse prong is missing as well. Why does it only have prongs on the left? Thats how mine is also.
Would gauges be ok to hook up to one of the two available connectors on the right? Also, what kind of fuse is the "tail" one?
VIC
Old 10-18-2007, 09:17 AM   #5
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I think that prong is just missing/broken. That fuse you are refering to is called a "circuit breaker".
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 10-18-2007, 09:23 AM   #6
Ronin8451
Ronin8451's Avatar
The missing spot you have is for the optional spot light, which is obviously not installed since you don't have the contacts to the right. You can hook a gauge up to the right hand contacts since they are "fused" and should be turned on/off by the ignition switch. Your AMP gauge is not fused and most people's consensus is that the old style amp gages are unsafe since you basically have to run the "main" power for the whole truck thru the gauge and they are prone to burn up and can cause a fire . If yours is not working, it was probably wired around to eliminate it. I would get an aftermarket volt gage to monitor the alternator since they are much safer !
Rick
1970 SS El Camino Resto-rod
1951 Chevy 3100 ( in pieces at the moment)
1964 C-10 Long Step ( new daily play truck)
1999 SS Camaro & 1994 BMW 740IL Daily drivers
1969 SS Chevelle ( next in the resto line)
Ronin8451 is offline   Reply With Quote
Old 10-18-2007, 11:05 AM   #7
salazar44
65 - Chevy C10
salazar44's Avatar
The circuit breaker controls the tail lights? in which way? stopping, blinking, parking lights?
VIC
Old 10-18-2007, 11:15 AM   #8
SkylineNXS
SkylineNXS's Avatar
the circuit breaker doesnt control anything really, its just another type of "fuse". It will pop if there is a short in the lines and too much power is drawn, just like in any household breaker. The tail lights are all controlled byt eh turn signal switch, brake light switch, and flasher...
BRAD
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
Old 10-18-2007, 11:33 AM   #9
64GMCHorsepower
Justified!
Well, the missing clip went to my dome light.......
You can hook up whatever you want , either using fused or constant power I would assume......
I am in the middle of replacing the fuse box, since it was old, and had a missing clip......lot of wires on the new one though..
Chad
Chad
Old 10-18-2007, 04:27 PM   #10
salazar44
65 - Chevy C10
salazar44's Avatar
But I noticed under the circuit breaker it says "tail" and "stop"
VIC
Old 10-18-2007, 06:20 PM   #11
64GMCHorsepower
Justified!
hmm, I can't help you there.....i would assume it was for the brake and tail lights......
Chad
Old 10-18-2007, 07:17 PM   #12
fuelpump
fuelpump's Avatar
Guys,
Here is the panel in my 60 shortbox. Does anybody know what the three fues go to? The only thing that doesn't work is the heater motor. Any help would be appreciated.
Name:  fues panel (Small).jpg
fuelpump is offline   Reply With Quote
Old 10-19-2007, 10:08 AM   #13
64GMCHorsepower
Justified!
Looks like the 2nd fuse from the top is the heater, at least it is on mine,...did you check the fuse with an ohm meter? that would be the easiest thing....if the fuse is good, ohm out your heater motor.....they are only like 25 buck if it is bad.....
Chad
