I found a 73-78 chevy big 10 truck bed made into a trailer. I looked underneath it because I figured it had a 12 bolt and I was right. I'm pretty sure I could bid on it for next to nothing and get it. Should I, or not? I would also like to know how to decode the axle to tell if it is a positrac. If it is I would be a lot more tempted to buy it. I am thinking about getting it for a drag truck when I get older. The truck bed is wasted basically the only thing I would take off of it would be the tail lights because they are the chrome strip around the edge ones.
-Lincoln 1987 GMC S15 (soon to be a chevy clone) ![]() 2.5l, 4 speed, no ps, no pb, no ac Silence is golden, but duct tape is silver. ![]() Spoken by Cletus the hillbilly I like stickers... a whole bunch. |
Re: 12 bolt
I'd grab it if you can get it for cheap. If anything, you've bought yourself is a good 12 bolt housing and axles to work with. I would just get a good aftermarket posi unit, your choice gear ratio if the ones in there are in bad shape or not what you want, and have it built with all new bearing, seals, and whatever else it needs.
If you get it cheap, you can probably sell the trailer for scrap metal and get some money back. Last edited by Pyrotechnic; 10-18-2007 at 01:55 AM. |
Re: 12 bolt
Yeah that's what I was thinking pull the trailer to the scrap metal yard and pull the 12 bolt and springs load it in my truck grab the lights, wheels, and tires (for rollers) and scrap everything else. Most big 10s had positrac right since the were meant to haul stuff?
-Lincoln 1987 GMC S15 (soon to be a chevy clone) ![]() 2.5l, 4 speed, no ps, no pb, no ac Silence is golden, but duct tape is silver. ![]() Spoken by Cletus the hillbilly I like stickers... a whole bunch. Last edited by abebummy26; 10-18-2007 at 02:49 AM. |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: 12 bolt
Why are you wanting to get a 12bolt so desperately? What are they worth in your neck of the woods?
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 10-18-2007 at 10:58 AM. |
Re: 12 bolt
I'm not desperate but I if I can get one for free almost if I scrap the rest of the trailer. I figured that would be a good deal for me. I have never seen one for sale, but I haven't looked.
-Lincoln 1987 GMC S15 (soon to be a chevy clone) ![]() 2.5l, 4 speed, no ps, no pb, no ac Silence is golden, but duct tape is silver. ![]() Spoken by Cletus the hillbilly I like stickers... a whole bunch. Last edited by abebummy26; 10-18-2007 at 12:19 PM. |
Re: 12 bolt
They aren't any stronger than a 10bolt. 10Bolts have beefier pinion shafts.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Re: 12 bolt
Thanks for the info that nixes that idea tyvm.
#8 | |
Magnificent bastard
Re: 12 bolt
1977 Big Block Burb |
Re: 12 bolt
The 10 bolt gets bad rap from the 7.5 inch ones that are very easily grenaded but the 8.5 units in these trucks are quite strong.
My heavy half GMC which is the equivalent to a Big 10 didn't come with a posi. All Big 10 means is 3/4 ton springs, big brakes, and heavy duty emissions. When it comes down to it, which do you guys think is ultimately stronger? The 10 or 12 bolt ? I know a 10 bolt is plenty strong enough to where finding a 12 bolt isn't necessary, but I'd just like to know which is ultimately stronger. Last edited by Pyrotechnic; 10-18-2007 at 02:09 PM. |
Wishin' I had more money!
Re: 12 bolt
In my neck of the woods I see 12 bolt rear end housings go all day long for 4-500 bucks, without gears... with gears they may bring even more.
Re: 12 bolt
ttt
#12 | |
Re: 12 bolt
BTW there is a guy on my forum selling a 12bolt for $75...
#13 |
Re: 12 bolt
Is the machine work to do it very costly?
1985 Chevrolet C10 305 2wd LOOOOONG Bed Broke as a joke and funny as a funeral |
#14 |
Right turn Clyde
Re: 12 bolt
If its for your truck you already have the best rear for strength. Assuming that your K30 still has its original rear. I could see getting a 12 bolt for a car setup. But with the 14 bolt sf/ff out there I don't see a need for a 12 bolt. Cheaper to buy and hold more power vs the 12 bolt.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
#15 |
Re: 12 bolt
No idea if that is possible, just know they aren't the same.
#16 |
Re: 12 bolt
Don't think so. The car pinion shaft is thicker (1.625") the truck is something like 1.4. I ordered a car set by accident and it would not fit.
#17 | |
Re: 12 bolt
#18 |
Re: 12 bolt
ttt
#19 |
Re: 12 bolt
I really need information on this. I know this is an old thread, but If anybody knows anything more that would be greatly appreciated. Btw I am going to school to be a machinist, so machine work is minor, to me anyways lol.
-Lincoln 1987 GMC S15 (soon to be a chevy clone) ![]() 2.5l, 4 speed, no ps, no pb, no ac Silence is golden, but duct tape is silver. ![]() Spoken by Cletus the hillbilly I like stickers... a whole bunch. Last edited by abebummy26; 01-08-2008 at 05:36 PM. |
#20 |
BAD BOW-Silverado XST
Re: 12 bolt
#21 |
Re: 12 bolt
lol thats true. Not exactly the answer I was looking for but I guess its a start.
#22 |
Chevys Kick A$$
Re: 12 bolt
I say go for it. If you can get it cheap and use it.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
#23 |
Cruzzzn' Vet
Re: 12 bolt
#24 |
Re: 12 bolt
in my neck of the woods a 12 bolt is hard to find..use to be a big deal back in the years..12 with a 4:11 was what everbody wanted ..didnt any of u guys use to race.
#25 |
![]() Join Date: Jul 2007
Re: 12 bolt
Find me a good Dana 60 and I'll trade you my 12 bolt...LOL the truck 12 bolt is not worth putting money into - not if you are going to make any power.
