Old 04-29-2002, 05:55 PM   #1
THOR 50
Over worked under paid
THOR 50's Avatar
Question E-brake cable routing
I've got all the hardware to reinstall the emergency brake system but can't find a diagram with how it all goes together. Any body have a pic or drawing for a '69 Long fleetside from the pedal to the rear?
Roger
'69 C-10 with GMC front clip billet grill, 283CI, 400TH and 12bolt posiw/3.73 gears
THOR 50 is offline   Reply With Quote
Old 04-29-2002, 06:35 PM   #2
Fast68Chevy
Fast68Chevy's Avatar
Post
prewtty basic, ill try and describe some of it, i assume you hahve coils rear suspension ?
the rear axle cables route to outside faces of the trailing arms and theres a clip for the end of the rear axle cables to sit in,
the rear axle cables ends get a small spread out C or U shaped bracket deal with slot in it that the intermediate cable end goes into also
the intermediate cable gones from one rear cable end to up front under rear or just behind rear of tranny and goes to other side of truck and then goes back to the other rear cable on the other side of truck,
there are four thick wire/rod deals that are bent so that the cable slides through one end and the other end is hooked to go in frame rail holes, one at about the tail of tranny on each sode of truck and one on each side a bit further back i believe, i think two are shorter than the other two, i forgot which length go in front and which go in rear, i can look on the 71 and reply again or someone else will
the end of the front cable that runs from brake pedal aseembly goes to about the end of tranny and theres threaded shaft and nut on the end of it, there is a small bracket with hole in middle that slides on the end of the front cable and then nut goes on, but you must sit the intermediate cable in the channel of this bracket before sliding the bracket onto the end of the front cable end, then put on nut, shoudl be two nuts actually, so that they can lock together to retain cable tension adjustment.
questions? if i had a digicam i owuld just go and take pics, but ill be damned if I iever get one... lol they cost too damn much, so...
Randy- Lincoln, IL
randy@ccaonline.com 2177353230
-71 C-10 350/CH465/3.07, assemble it, yeah right, that'll happen in this world,(not)
-84 Z28 Camaro 5.0L 700R4, 3.73, beater, paid way too much for it like an idiot,,
-84 Firebird SE 2.8L T-5, rod knocking, dammit,,
-82 Firebird 350 4bolt (TBL)/TH350, not running, dammit...
buy/sell/hoard/trade most any GM vehicle parts of any kind
-parting out: '81 Cutlass Supreme Brougham
*Paint is overrated
© RSS Enterprises 2000
[This message has been edited by Fast68Chevy (edited April 29, 2002).]
Fast68Chevy is offline   Reply With Quote
Old 04-29-2002, 06:51 PM   #3
THOR 50
THOR 50's Avatar
Question
Yes 1/2 ton w/coils on the rear. I also have a rod that is a little over a foot long that goes through the frame on the passenger side that is part of the assembly. Any ideas how its incorporated?
[This message has been edited by THOR 50 (edited April 29, 2002).]
Roger
Old 04-30-2002, 10:12 AM   #4
scull67
scull67's Avatar
Post
The longer rod hooks into the frame and holds the inter cable in the front on the driver side so it can make the turn to go back. There is a diagram in the LMC catalog. I am going to try to hook the pieces of mine up soon. Good luck.
Hoboken, N.J.(home)/ Washington, D.C.(work)
scull67 is offline   Reply With Quote
Old 05-02-2002, 03:57 PM   #5
THOR 50
THOR 50's Avatar
Post
Appreciate the input.
Roger
Old 05-02-2002, 06:43 PM   #6
Fast68Chevy
Post
i was wrong on the metal bent hanger rod thingies, only are two, one on each side and are back almost to the carrier crossmemeber under cab back wall pokes through a fram,e rail holwe, the straight rod you mention is for driver sie and the middle long cable that loops all from left to right side of truck goes through the bracket deal on the end of the rod
Randy- Lincoln, IL
*many GM parts bought, traded, or sold -am parting out: '81 Cutlass Supreme Brougham
current fleet: -71 C-10 350/CH465/3.07- basketcase
-84 Z28 5.0L/700R4/3.73 daily driver
-84 Firebird/SE 2.8L/T-5/3.73/engine bad
-82 purple Trans Am, project #2
*Paint is overrated*
Old 08-04-2002, 07:40 PM   #7
THOR 50
THOR 50's Avatar
ONE LAST THING
looks like the cable goes over the transmisson cross member, Correct? And last question . . . The cable looks like it goes through the cross member that the trailing bar arms bolt to. There is a side ways triangle cut out there and 2 smaller round cut outs. Which does it route through?
Roger
