still buypickupparts
wiring connections original to LT1
ok sorry but I will admitt, I'm not the sharpest electrical guy. I will share with you I have most of the wiring of the LT1 Harness complete. now my question is the harness that use to go to the altenator (it was a internal voltage regulator set up) now with the LT1 harness connected to the new Internal reg. altenator what and do i and how do I connect my original altenator wire harness to the new instalation. the LT1 alt. wire plug (after taking the tape off from the wire harness from the LT1 there is only one wire plugging into the altenator from a factory 4 wire connector. so I know well Im thinking that well I must need to connect the trucks (by the way its a 72) original wire harness for the altenator back up. please I sure could use some detail explaination for this please
Its Gonna be a Great Day, I woke up this Morning. 72 SWB Fleetside freshly painted. putting a 94 LT1 with 700R4 tranny lowered 4 in the front 6 in the back 81 chevy half ton 350 89 Silverado 4x4 going ta church truck |
Re: wiring connections original to LT1
ttt please
some one has done this before there is gotta be an answer
There are 4 terminals on the alternator labeled SFLP. Wire the "S"to the #2 wire on old alternator and the "L" to #1. Here is a link that may help http://paceperformance.com/index.asp...=Custom&ID=650
The start of a new toy 1967 GMC 3/4 ton |
thank you Rstewart09, this is a big help
