Old 10-18-2007, 09:04 AM   #1
space
Lowering 72 Chev 1/3
Originally, I thought I needed to drop my truck 3/5 to get it level, but now that I look at this page at LMC, it appears I only need a 1/3. Should I still get spindles if I'm not going over 3" on the front? How much will lowering it effect the ride quality? Hard to install? I don't mind putting the spindles in but if the ride quality is basically going to be the same, I can't justify the additional cost or time. Also, since this is a mild drop, will I just need the springs or will I need lowering shocks? I know this is a lot of questions and I appreciate any replies.
space is offline   Reply With Quote
Old 10-19-2007, 06:55 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Re: Lowering 72 Chev 1/3
There's a ton of variables here. It's possible your front springs are already dropped 1" if they are original. In that case just buy a set of rear springs!. Spindles will maintain better geometry for front end alignments but they cost more and are more work to install as you know. Those LMC pics are a rough guide only. My truck is about 4.75 front (2.5" spindles and 2.25-2.5" cut springs) and 4" rear springs (eventually will add a 1" block) and it does not look like those pics. If you go with a 2-3 drop in the front (spindles or springs), stock shocks should be fine. We recently spent 90 minutes to remove, cut and reinstall the front springs to lower it more. That also included installing new KYB Gas Adjust shocks I'm a big fan of cutting front springs rather than buying them. I have never noticed a difference in ride quality. Take your measurements right now and post your tire sizes and maybe pics and we can give you more opinions on which way to go. Also how is the truck driven?.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-22-2007, 06:50 AM   #3
space
Thanks for the reply Jim. I just drive it on the weekends. Forged 383 is almost ready I went ahead and ordered the new springs last week. I installed the rear springs Saturday, which only took about an hour. It definitely made a difference. I'm still waiting on the front bushings so those springs aren't installed yet. I'll post some pics in a bit.
Old 10-22-2007, 04:01 PM   #4
70c10
67-72 Addict!
70c10's Avatar
If you decide you want to go lower on the rear, you can always buy lowering blocks in half inch increments, ie., .5", 1",1.5", 2".
Jim
