tiggerstoy
in need of 55 2nd rad
im looking for a 55 2nd original rad, im in alberta canada...pm me if you have one for sell, and how much, thanks.....max.
Re: in need of 55 2nd rad
a radiator out of a 65 chev truck is more avalble and rthe right dimensions, just build a frame out of angle iron use three rubber cushion mounts two on the bottom and one on top the angle iron can line up with the factory holes and the change will last longer becasue of less vibration especially if you have a v8
#3 | |
tiggerstoy
Just in case you can't find what you're looking for close by, you can check out Scott's Super Trucks in Penhold. He'll have everything you might want or need for your project.
#5 | |
tiggerstoy
