Oh,you can't buy that new
![]() Join Date: Apr 2000
67-72 utilty trailer. Low,Fat & cool, $550, NJ
This is a 1/2 ton 8' pickup truck bed utilty trailer.
I am not answering specific questions about the condition of the truck bed itself other than I KNOW it has plenty of bondo in it. it is pretty straight and has been done appx. 2 years. I have no idea about the differential under it either other than I added two new quarts of gear oil. I am not selling it to use on a Chevy/Gmc truck. It is Just a cool looking 67-72 trailer now and nothing more. It is MORE than solid enough to perform the task of a LIGHT DUTY trailer though. It has new lowering coils and new drop shocks along with a new track bar, nice used rims and new,275-60-15 tires installed right before the wreck-oh well! you can swap parts around with your truck all you want once it YOURS. I'm not selling anything off it. There are a few flaws in the bed that happened in the accident, but they are minor. it cracked a bit of the bondo in the right wheelwell and has a scrape just below the marker light. I installed a new 2000# flip-up jack and safety chains. the lights work and it goes down the road straight. the first time I used it, I hauled 500# of parts to a swap meet and it was steady as a rock going down the road. The trailer got more attention than my parts did. It uses the standard GM 12 bolt , 5 LUG, rear axle. It uses a 2-15/16" ball and if you have a 2WD truck that you are going to tow it with I have a good hitch I'll give you. The tongue is made from original frame with a stiffner added and good welding. All the lights work. the tailgate works and has some lumpy body work, but it is fairly solid except the inside bottom edge. Factory sport bumper in decent shape too. provisions inside rail for a hard tonneau also so you could stow your stuff at the shows. ***NOTE*** NO trailer registration- it's easy to get done in most states and cheap. ALSO as it sits right now I would not buy this to haul anything over about 800-lbs. MAXIMUM. $550 Cash. Call DAVID 856-678-7883, 9am-9PM EST LOCATED; In Pennsville, N.J. 08070. New Jersey routes 295, 40, 130,and 49 along with the NJ turpike all end right here in Pennsville at the base of the Delaware Memorial Bridge and I am only 5 minutes from the base of the bridge and easy to find. thanx for taking a look
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone 73 Pinto, stock, w/CragarSS's-eww ![]() 84,C10 SWB-Yella,stock 86 K10 SWB-Red, hopped up 305,4/S LOTS of Cummins trucks. Last edited by crossy; 10-18-2007 at 07:21 PM. |
Re: 67-72 utilty trailer. Low,Fat & cool, $550, NJ
one more
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone 73 Pinto, stock, w/CragarSS's-eww ![]() 84,C10 SWB-Yella,stock 86 K10 SWB-Red, hopped up 305,4/S LOTS of Cummins trucks. |
Led Sled! Discs R 4 ME!
![]() Join Date: Jan 2001
Dave,
Why do you say "800-lbs. MAXIMUM" load? Denny |
SOFT drop springs, and mushy drop shocks with a lot less travel. thanx for the bump.Crossy
![]() Join Date: Aug 2006
Dave, The parts worked great. Thanks again. ttt
| Bookmarks |
