20X10's
Is anyone running 20X10's on the rear? What offset do you need and what size tire works best? Do they fit better under a fleetside or stepper?
Truck Enthusiast
Re: 20X10's
im running 20x10's with a 4.5" backspace on my '68. i think on your '72 you'll need at least 6" of b.s.
they fit well also with a 295/40 tire
'85 swb |
![]() Join Date: Aug 2006
Re: 20X10's
I am also running 20x10's with a 4.5" backspacing and i just BARELY fit. I think i have a 1/4-3/8" of clearance on each side. I am not sure what year of rear end i have but my truck is a 70. It was restored about 10+ years ago so my grandfather might have swapped rear ends. Anyways good luck.
Josh
(Project truck) 1970 C10 under complete transformation ![]() My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
Re: 20X10's
Ask this question enough & you'll have enough answers to confuse the heck out of you. Every truck is set-up slightly different so measure the BS for yourself & be sure.
If you have a wheel on it now that's the starting point you need. Just add a tape measure & some scrap wood & you can firgure it out pretty easily.
Re: 20X10's
don't have the wheels yet, and don't have the bed on to check, was wanting to know before I bought some wheels, found a good deal ona set....my truck is 1970, with the original rear in it. I have two 70 chevy's, 72 GMC, and a 69 c30 flatbed.
#6 | |
Re: 20X10's
I'm sure you'll get several other responses. For mine..... 10" wheel, 5" BS, 68 short fleet 6/8 drop.
Re: 20X10's
bump
Re: 20X10's
ttt
"1972 C5"
Re: 20X10's
I've got the 20x10s too. I think the bs would be the same (or close) even on a blazer.
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: 20X10's
1972Ryan,... Like SCOTI said,... you would be better off putting the bed on and measuring. I know this is alot of work,... but so is spending money on wheels that don't fit. If they're 1/2" too wide they might as well be 2" too wide. Also, your '70 model truck could have the early narrow rearend, (68-70),... or the later WIDER rearend. (71-72).Take any wheel, (idealy with no tire), and mount it on the rearend. Take a tape and measure out to the wheel well, and in to the wheel tub. (Remember a 20x10 will actually measure 11" wide across the rim) Take the given BS of the mounted wheel and add whatever you can safely fit. Also,...I usually add 1" for tire bulge and 1/2" for clearence. Hope this helps!
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 10-19-2007 at 11:04 PM. |
Re: 20X10's
what about with a 4 inch backspace any way at all that might fit...what about adding spacers? What I mean to ask is anyone running a ten inch wheel with a 4 inch backspace and does it work on the early 70 rearend?
#12 | |
Re: 20X10's
One of the other members has 20x10's w/4" BS. His rearend was out of an early f-body so it was approx a couple of inches narrower but it did look good w/the deeper wheel lip.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-26-2007 at 10:53 AM. |
