Help with SBC Engine ID
Hi all,
Could someone please decode my Engine Plate ID? This is the plate on the passenger side front of block. ----15J110289 1 082bCTU----- Small "b" for SBC Dunno Thanks in advance, Rob |
Re: Help with SBC Engine ID
thanks for the quick response. The link is very informative(is now a saved favorite site) but it only has casting information that I saw. I have the generic 3970010 code. I need help explaining what the ID code is about, but this could just be over my head and I missed the information you were trying to send me to.
Did I miss it? Thanks again, Rob |
Firstly your engine is one of this but I have to check the year at home!
Code Year CID Vehicle HP RPO Trans Carb Comments CTU 70 350 Corvette 370 LT-1 4-spd 4-Brl Holley, Hp Solid Cam CTU 75 400 Chevelle 175 LT-4 T-H 400 4-Brl CTU 76 400 Impala 175 LT-4 T-H 400 4-Brl CTU 76 400 Chevelle 175 LT-4 T-H 400 4-Brl
'71 Custom/10 Deluxe LWB '71 Custom/30 Deluxe Dually |
I have a radical idea!
There is a code casted into the block, usually in the rear, that will be a letter, space, 2 digit number, space, 1 digit number. For example, G 24 5. The letter represents the month, the second series of numbers represents the day, and last reresents the last digit of the year. With that being said, if this was the casting date on your 3970010 block, it would mean July 24, 1975. That will help you break down which CTU code it is. Sure would be nice if it were the '70 LT1 since your engine is a 350. The date code would confirm that.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 10-19-2007 at 04:55 PM. |
I climbed in the engine bay myself and checked out the casting number it is NOT 3970010, like the PO said
![]() ![]() Also the CTU number is actually ----15J110289 F 082bCTU----- I am not sure if that changes anything. I just got the truck about a month ago and have just now started seeing what I am starting with. Guess I am setup like this- 400 SBC, TH400(this I do know for sure by the pan), 12 bolt rear. I am not sure that the gearing is yet but it is REALLY short. About 50 mph = 3000 rpm in top gear with 295/50R15's on the rear. The rearend also has a detroit locker "no-spin" posi. The PO also had a NOS nitrous system installed, I already took that out. Now I need to figure out the steps of turning a strip truck into a highway friendly cruising beast. Open to all suggestions. Thanks all for the help, Rob Last edited by SunTzu; 10-19-2007 at 07:24 PM. |
