Old 10-19-2007, 12:15 PM   #1
matthufham
Question parking light works only with hood open?
that's my problem i discovered today. this concerns my front driver side parking lamp.
the turn signal works whenever, the parking light works with the hood open, and doesn't work with the hood fully shut.
the turn signal indicator lamp on the dash stays lit up when the light doesn't work (hood closed), and goes away when the light works (hood open)
the indicator lamp on the dash sometimes flickers when driving. i'm totally lost here.
it's not stock, my lights are behind the grille. i rewired the pigtail yesterday because i thought the parking light was fused to the turn signal wire somehow, but that isn't the problem since i still have this problem.
everything worked fine til a few months ago
matthufham is offline   Reply With Quote
Old 10-19-2007, 12:52 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: parking light works only with hood open?
Ground wire broke or needs to be cleaned?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-19-2007, 01:43 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
Ground wire issues, that is why the turn indicator stays lit on the dash. When you close the hood, you are undoubtedly creating a change in something's position that opens the circuit.
piecesparts is offline   Reply With Quote
Old 10-19-2007, 02:29 PM   #4
grayw0lf
Do a search on here. Someone else had a similar "hood on/hood off" problem here about 6 months ago.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 10-19-2007, 05:27 PM   #5
matthufham
dont ask me how because i dont know but i fixed it
i moved the wire bundle near the hood hinge and everything works fine now... it's all sealed up so i have no idea why that made a difference and the hinge never touched the bundle...
thanks for the suggestions
Old 10-19-2007, 11:04 PM   #6
68K20 x Drill
If the hood is down. you should be driving.
If the hood is up, you should be parked.
Seems simple enough
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 10-20-2007, 06:29 AM   #7
Boog
laying low
Boog's Avatar
Something tells me you will be experiencing this problem again...
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 10-20-2007, 12:33 PM   #8
matthufham
hey boog. ur right, it comes on whenever now. random on random off. i dont know why.
Old 10-20-2007, 04:05 PM   #9
Longhorn321
Size Matters
Longhorn321's Avatar
You have a loose connection or loose ground somewhere. If it changed when you moved the harness then that is where you should start. Usually, a wire does not just break in the middle so look for connectors that are close to where you moved the harness. You could also check your voltage/ground at the light to see which one you are missing. If it is a bad ground, you will have voltage on one of the pins when you put your black lead on the neg. post of the battery and the red lead on the pin.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News.
...WOOOO HOOOO!!!!
Longhorn321 is offline   Reply With Quote
