Old 10-19-2007, 07:28 PM   #1
1969k10stepside
Using 73-87 springs on a 69
So,I'm using these springs from a 73-87 since they were free,they are 6" lift springs and since they are longer,what can I do to make them fit? Will a longer shackle allow enough room to work? Who sells a shackle long enough to allow enough room?
Here is a pic with just the spring on there...
1969k10stepside is offline   Reply With Quote
Old 10-19-2007, 07:47 PM   #2
Tigman
Re: Using 73-87 springs on a 69
Check out diy4x4.com Kert is great to deal with!
Tigman is offline   Reply With Quote
Old 10-19-2007, 09:39 PM   #3
msgross
msgross's Avatar
you could use a 73-87 truck to make them work properly!
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 10-19-2007, 10:34 PM   #4
earl87gta
earl87gta's Avatar
if the tires are centered on the wheelwell were you want them I would just move the rear spring hanger back and weld the old hole up if you make a longer shackle your still going to have truble with the eye of the spring wanting to rest on the frame.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 10-20-2007, 12:09 PM   #5
You need to relocate the rear mounting point in the frame,like earl said.
