10-20-2007, 02:04 AM | #1 |
68 Tilt column Install
Got the new column preped and painted it. Made the mod for the netural safety switch. Easy mod when column is apart. The 72 column has a 36 spline shaft, are you using the center shaft from the van to attach it to the steering box The 68 shaft is one piece all the way to the slip sleeve with no splined coupling to attached it to the column any help here would be great.
10-20-2007, 03:53 AM | #2 |
Re: 68 Tilt column Install
The shaft extension for the 69 up trucks should work well for you but you will need to collapse it a bit.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
10-20-2007, 10:47 AM | #3 |
Ditto!! You just need the rest of a later 2-pc column.Doesn`t need to be tilt.
10-20-2007, 03:14 PM | #4 |
Thanks guys, I knew that somthing would fit but just didn't know what to look for. Thanks for the help
