Old 10-20-2007, 10:21 AM   #1
rick0312
rick0312's Avatar
pulling motor?/block drain bolt
before pulling the motor do I need to drain the atifreeze from the block? Where is the drain bolt typically located on the block? thanks......rick
rick0312 is offline   Reply With Quote
Old 10-20-2007, 10:51 AM   #2
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Re: pulling motor?/block drain bolt
Yes .... the pet cock is located on the rad at the bottom.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 10-20-2007, 11:26 AM   #3
cdowns
cdowns's Avatar
there is do drain on the engine block
Old 10-20-2007, 12:26 PM   #4
rick0312
rick0312's Avatar
the rad is out I was just wondering if there was a drain bolt on the block....thanks for clearing that up for me cdowns.......rick
Old 10-20-2007, 01:06 PM   #5
38chevyhotrod
38chevyhotrod's Avatar
On my v8 small block I have one plug on each side of the block.
It can be used by a temp sensor, if you unscrew those plugs most of the fluid will be gone.
Anybody can restore a classic, takes a man to cut one up.....
http://www.arnoldscustoms.com
38chevyhotrod is offline   Reply With Quote
Old 10-20-2007, 02:36 PM   #6
brak
brak's Avatar
I agree.
If you are going to tear apart the engine, that will help evacuate the heads, and eliminate a possible mess
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 10-20-2007, 03:01 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
yep, and on putting it back together, you can actually install a petcock to where you can drain it when ever you are doing a drain/flush of the cooling system.
if you remove the plug/bolt and nothing somes out, poke the hole with a small screwdriver.
Old 10-20-2007, 06:04 PM   #8
rick0312
rick0312's Avatar
thanks! the motor I am pulling is a 305 so i am not going to tear into it. replacing it with a 350.
Old 10-21-2007, 06:23 AM   #9
brak
brak's Avatar
Then i wouldn't worry about it, unless you plan on standing the motor on end.
