Old 10-20-2007, 06:16 PM   #1
blazntn
Early Classic and Air Ride tech
Ok guys, I just removed the rear setup on my 69 truck. I was wondering if it will fit a 2 wheel drive blazer. I have the notch, panhard, and shock relocators?
blazntn is offline   Reply With Quote
Old 10-20-2007, 08:56 PM   #2
babyblueoval
babyblueoval's Avatar
Re: Early Classic and Air Ride tech
blazntn,
I got your PM and I'm pretty sure it didn't answer this question.
I do believe I've read somewhere that, other than the obvious length difference, the frames are the same as far as the hoop and mounting locations go. The trailing arms will be shorter and the distance from the cab mounts to all the suspension components will be less.
You planning on using your old set-up on Chad's Blazer? That would be very cool.
Jim
'71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E
'57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works
'87 BMW 325i - daily driver
babyblueoval is offline   Reply With Quote
Old 10-20-2007, 08:57 PM   #3
71swb4x4
71swb4x4's Avatar
Yep, that will all fit.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 10-20-2007, 08:59 PM   #4
71swb4x4
71swb4x4's Avatar
The trailing arms are not shorter, they are the same length on Blazers, short beds, and long beds of the 67-72 era.
Old 10-20-2007, 09:37 PM   #5
blazntn
ok next question, does anyone know where I can get directions on how to install the bolt in notch and shock relocators.
Old 10-20-2007, 09:38 PM   #6
babyblueoval
Oops. Sorry 'bout that. I thought they were shorter.
They just mount closer to the front?
Jim
Old 10-20-2007, 09:40 PM   #7
71swb4x4
71swb4x4's Avatar
Here's a thread on the C-notch:
http://67-72chevytrucks.com/vboard/s...d.php?t=195566
Old 10-21-2007, 08:01 AM   #8
blazntn
Thanks that helps!
