Addicted to Chevy
brake booster question
i know this has probably been asked before, but how much work would it take to swap my non-power brakes over to power brakes? just add the booster or would i need a new master cylinder as well?
glamoros piece o' lowlife
Re: brake booster question
Yes, you will need a master cylinder too, but they're cheap. What power brakes are you going for, vacuum assist or hydroboost? I went with the hydroboost cause of my oversized tires, it works ridiculously well and is also much more compact than the vacuum brakes. You will need good brake lines and hose for it tho, or you may end up blowing something like I did when I was testing them at my place before I drive it.
The more I drink, the more I drink, the more I drink... diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express |
wow, I was just going to post almost the same question, sorry about jumping in. I have a 73 with manual brakes and a 76 parts truck with a power booster and no master cylinder. I think I can bolt the booster on mine, but do I need to buy a master cylinder for a 76? Also the booster doesn't have a push rod hanging out of it, can I get one and do I need it? My truck has a straight six, where do I hook up the vaccuum hose. Thanks in advance, Bob
Bob, the hose for the vacuum supply is supposed to go to a strong manifold vacuum source, usually the 3/8" port on the back of the carb. The booster may or may not bolt to yer firewall, I seem to recall something about them studs being weird - the brake booster has at least 4 studs already attached to it that need to go through the firewall and have the nuts on the inside of the firewall, but the firewall of manual trucks already got two studs sticking out of it where the old MC bolted in. It may be possible to punch those studs out of the firewall and bolt in the brake booster, but in my hydroboost conversion I did just the opposite - punched the two studs out of the hydroboost and slided it onto the ones sticking from of the firewall. As far as the rod goes - my hydroboost units always had one attached to them, I'm thinking the vacuum one you go should have something too, unless it's a detachable part (not the case with the hydroboost, can't remove the rods there) - really I'd suggest finding a vacuum-boosted truck and looking at its setup, that should give you some better info than I can come up with.
Edit: master cylinder - there are two types of master cylinders, one is for hydroboost, and the other is for vacuum assist, difference is the depth if the blind hole in the back of the piston that the rod from the booster goes in - bring the booster with you when you go to buy the new master cylinder.
The more I drink, the more I drink, the more I drink... diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express Last edited by Ivan D.; 10-21-2007 at 01:39 PM. |
Thanks Ivan appreciate the info, sounds like it will work out for me just fine I think it will be a nice addition. Thanks again. bob
It Is What It Is,,,,
Hmmm, So I want to do the same thing. I got myself a booster, So I need to change the MC??
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture ![]() My Rat Den ![]() |
Man, that's one nasty brake booster, pleas hit it with the wire brush and the rattle can before you install it
![]() Also, notice how the vacuum assist booster has 6 holes on the bracket, the top ones you will not be using as the firewall behind them is solid - if you want you can drill and insert studs I guess, but tis not necessary. So from the stock firewall loosen the 4 nuts (two for the master cylinder, two below it covered in dirt and grease and grime), and the vacuum assist booster will slide right on the studs - reuse nuts and tighten them with a box wrench, a socket and ratchet will likely not fit because of the bracket's shape. From there on tis as simple as bolting up the new master cylinder, filling it up, bench bleeding it with the supplied kit, and bolting up the brake lines.
So the 2 bolts holding the M/C and the 2 bolts on the plate,, And that booster will bolt up?
But oh yea.. will be taking a wire brush to it and por15 aswell.
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Since you have manual brakes those top 2 holes are where the studs would normally go to mount the bootser. You need those holes to house the studs as it takes 6 to hold the booster on.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Are those things all that heavy? Those are 3/8 or 7/16" studs after all, I tried cutting one just for a test once and they are pretty darn strong. By the way all new Chevy vans have the hydroboost attached with just 4 bolts, I was thinking of snagging an extra one from work just for neatness purposes as it will bolt right up at the firewall.
So whats going to be involved in getting those 2 bolts in on top?
#12 | |
#13 |
Living Legend
If i may?. how difficult is it changing from vacumme to hydro, thats a change that i am going to be making as the cam in mine kills my brake pressure at lower rpms,
'81 c10 sw 355cid roller motor 350turbo with stage two shift kit, poor rear end gearing, not sure peg speed... speedo is mia.. ![]() project is temporarily on pause again... Thankyou wonderfull economy.. check it out Im not to worried i have an uncaning ability to save myself from some weeeiiirrd crap East Ok meet East Ok date Tony ![]() |
#14 |
you need to swap the vacuum booster out for the hydraulic one, it should hook right up to your brake pedal. Master cylinder may or may not need changed, new master cylinder can be had for under $30 usually. Remove the high-pressure line you now have, hook up the two pressure lines that come with the hydraulic booster (one goes to PS pump, the other to the steering box), T-ee the return lines from the booster and the box together, and that's about it.
#15 |
It'd take drilling the firewall and finding a way to reach up there under the dash with a socket for inserting/tightening the studs/bolts. Tho as I said you don't really need them, new Chevy vans use only the lower 4 studs, the bracket don't even have provisions for the top two.
