Old 10-21-2007, 12:13 AM   #1
Husker
Husker's Avatar
WTB a Disc Drum Proportioning valve
Any one have one in Good working order? Going on a 70 GMC 4x4 with power brakes( doing the switch from non power to power). Thanks
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 10-21-2007, 12:17 AM   #2
70c10
67-72 Addict!
70c10's Avatar
Re: WTB a Disc Drum Proportioning valve
I got mine in a junkyard for $5. You may try Billsbowtie or teeitup, they might have some.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-21-2007, 07:48 AM   #3
uncle
I don't think you have to change it unless you're also going from drum to disc.
uncle is offline   Reply With Quote
Old 10-21-2007, 09:50 AM   #4
Husker
Husker's Avatar
Sorry my bad, I am going from Drum/drum non power to Disc/Drum Power. Will other year, models, etc. work
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 10-21-2007, 07:05 PM   #5
xshadow
I'm doing just about the same thing. I'm going from power drum/drum to power disk/drum. My truck isn't together yet, but I hope to drive it before winter...will I have to change this?
xshadow is offline   Reply With Quote
Old 10-21-2007, 09:48 PM   #6
Husker
Husker's Avatar
Xshadow I think you will just have to change your Proportioning Valve and MAYBE your front flexible brake lines.
Your booster should be OK.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 10-21-2007, 10:25 PM   #7
yellowGT
yellowGT's Avatar
Does anyone have a picture of what the prop. valve looks like cause im in the process of changing my 6 lug drum power front end to 5 lug disc power from a square body chevy but dont know what all parts I will need. Some people tell me spindles, rotors, calipers. Some tell me that along with the control a-arms. Others tell me that along with that prop. valve. Correct input would be very highly appreciated. Thanks guys.
By the way, I have a 69 with power brakes cause it has the booster and master cylinder. Parts are coming from a square body chevy.
yellowGT is offline   Reply With Quote
Old 10-21-2007, 11:12 PM   #8
xshadow
I almost have the truck in driving condition. All of the lines are new as well as the flexable lines I still need new calipers. I hope the pro. valve will work. this truck is really more of a beater to drive around/haul. I do want to drive it this winter
Old 10-21-2007, 11:14 PM   #9
xshadow
I'll know if it will work soon...
HUSKER...not trying to highjack your thread...let us know how it works out for you so I'll know whats going to happen with my brakes.
