10-21-2007, 12:46 AM | #1 |
Junior Member
Int or ext regulated alt?
Fried my alt, need a new one. What's the advantage of an internally regulated alt? I think my voltage regulator is OK... Also, how many amps do I need? I will have a few accessories like driving & fog lights, power mirrors, power door locks. What is the capacity of the stock alt?
10-21-2007, 09:02 AM | #2 |
Re: Int or ext regulated alt?
if you look closly by one of the mounting tabs [ i think it's the bottom one] the amperage is stamped on them. i have seen 37, 53, and 68amp on externaly regulated 94 is pretty common on internaly regulated and 105s are available
common sense isn't so common anymore |
10-22-2007, 01:21 AM | #3 |
Internal is better and the wiring mods are simple
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap |
10-25-2007, 10:17 PM | #4 |
Junior Member
Just ordered an ext regulated 80 amp alt from Summit, then I read in Ron Francis' catalog "Don't use GM externally regulated alternators. They were done away with years ago for a reason." Then again, Ron says a lot of things in his catalog...
10-25-2007, 10:59 PM | #5 |
If you are going to get a new one, go for the internal regulated, get a kit for about $15, it has a plug that plugs into the ext reg plug and and another to plug in the the alt. Don't go over about 60-80 amps as the stock wiring to the battery is a weak link. Advantages are more stable volts at low rpm and eliminate lights flickering, plus most stockers were only 35 amp or so. You can get a rebuilt 55 amp from any parts store for about $40, get one for a 1977 1/2 pickup for example. Most will take your old ext reg alt for a core as they look very similar, most don't check or know the difference anyway.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 10-25-2007 at 11:01 PM. |
11-01-2007, 01:21 PM | #6 |
Junior Member
Got the alternator installed and it worked for a while until a connector on one of the wires disintegrated. Not quite sure how that happened, but it left me stranded and in need of a jump. It was the single wire with the rubber boot (?) around the connector, on the drivers side of the alt.
11-01-2007, 02:07 PM | #7 |
Internal... all the way!
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! |
